Finally got a normal sized jointer! Craftsman 21706
Forum topic by William Shelley posted 05-13-2015 05:41 AM 3574 views 0 times favorited 8 replies Add to Favorites Watch
View William Shelley's profile
William Shelley
564 posts in 1432 days
05-13-2015 05:41 AM
It’s not an Oliver but it’s a huge step up from the Grizzly benchtop jointer I was making do with. I found this for $150 on craigslist today, and I beat out 7 other people in getting to it first. Early bird gets the worm, or, the jointer in this case. It also came with a craftsman mobile base. According to the specs on Craftsman’s website, it’s got a 2HP TEFC motor and a 4” dust port, although I appear to be missing the dust port. Bed length is 46-1/4”
It’s got a teeny bit of surface rust but that may even be from it getting rained on en-route. I haven’t run anything through it yet, but it does run smooth and quiet. The seller powered it on for me before I bought it.
Sorry for the terrible picture quality, I don’t have a decent digital camera and my cellphone is a potato when it comes to taking pictures.
-- Woodworking from an engineer's perspective
8 replies so far
View MrUnix's profile
MrUnix
6581 posts in 2162 days
#1 posted 05-13-2015 06:11 AM
Nice get and a great price. Not sure where you got the 2hp spec though… Sears AFAIK no longer sells a Craftsman branded jointer, and none are listed on either the sears or craftsman web site. The manual claims a 1hp motor, which is plenty for a 6” jointer… but the actual size is pretty easy to verify by just looking :)
The ‘dust port’ is just a plastic insert thing and should be pretty easy to replace if needed..
William Shelley
#2 posted 05-13-2015 06:17 AM
Whoops. Yeah I didn’t get under/inside the cabinet yet to look at everything. The smooth running and the price was enough to make me not question much when I was picking it up.
For what it’s worth, the Sears website shows it at 2HP. Although I think on a 6” jointer the only thing that could bog down even a 1hp motor would be hickory.
http://www.sears.com/craftsman-professional-6-1-8-in-jointer-planer-stationary-3/p-00921706000P
MrUnix
#3 posted 05-13-2015 06:49 AM
For what it s worth, the Sears website shows it at 2HP. Although I think on a 6” jointer the only thing that could bog down even a 1hp motor would be hickory.
LOL – that is one strange (and old) web page! “Lock-on” power button for less fatigue? Adjustable depth gauge gives precise drilling? And the infamous “Develops” up to 2hp… yet the manual states 1hp. Sounds like part jointer, part drill press :)
PS: And I doubt even hickory would bog it down… I’ve done live oak, which is much harder than hickory, on a 6” jointer with a 1/2 hp, no problem. As long as your knives are sharp, 1hp will handle pretty much anything you throw at it. 2hp would be overkill!
View dozer57's profile
dozer57
92 posts in 1463 days
#4 posted 05-13-2015 03:05 PM
I have the same jointer, it works great with plenty of power. Bought mine at an auction sale for $80 and use it alot. get a 4 inch dust port as it is messy with out it, mine will plug with out a dust collector hooked up.
William Shelley
#5 posted 05-13-2015 03:28 PM
- dozer57
$80 that’s a smoking deal. Do you think a shop-vac with a 2-1/2” hose would do as well as a dust collector, assuming the shop vac was only hooked to one tool at once?
View TheFridge's profile
TheFridge
9249 posts in 1449 days
#6 posted 05-13-2015 04:00 PM
Should be fine. It may clog when jointing near its 6” capacity because of the size of the chips. Only one way to find out.
William Shelley
#7 posted 05-14-2015 08:51 PM
Well, I got it all set up last night. Even after being lifted and moved around several times, everything was still aligned perfectly. I jointed the edges of two 5ft long 1×6’s with visible bow, and after running them both through and butting the jointed edges together, there was no light visible between them for the whole length.
One thing I did notice is that the cutterhead speed seems slow. It’s a 3-knife cutterhead, supposedly spinning at 5000 RPM (no-load) but it leaves significant scallop marks on the jointed boards unless I use a quite slow feed rate.
How can I diagnose / change this? My first thought is that I could swap the motor out for a 1HP 3-phase one and install a VFD with single-phase 120v input, and overdrive the motor speed (75-90hz). My concern is that the blades might fly off.
View Timberwolf323's profile
Timberwolf323
69 posts in 806 days
#8 posted 02-22-2016 06:52 AM
Tack weld the blades to the cutter head to be sure.
