can I use titebond II for cutting boards since is water resistant?
« back to Joinery forum
Forum topic by Jorge Velez posted 05-13-2015 01:33 AM 4773 views 0 times favorited 19 replies Add to Favorites Watch
View Jorge Velez's profile
Jorge Velez
356 posts in 2609 days
05-13-2015 01:33 AM
I have a question for you guys out there more experience than me.
Your valuable imput is mucho appreciated.
-- Jorge Velez, Guadalajara, Mexico.
19 replies so far
View Ghidrah's profile
Ghidrah
667 posts in 1245 days
#1 posted 05-13-2015 01:46 AM
I used yellow Elmer’s glue on the 1st oak board I made somewhere around 35 yrs ago, its still together, it sits in hot soapy water to get cleaned and drip dries. No cracks splits checks or credit cards, I soak it in mineral oil maybe every 10 yrs or so.
-- I meant to do that!
View Jim B's profile
Jim B
58 posts in 1253 days
#2 posted 05-13-2015 01:50 AM
Titebond’s website says both II and III are safe for food contact and says they are both good for cutting boards too.
http://www.titebond.com/product.aspx?id=2ef3e95d-48d2-43bc-8e1b-217a38930fa2
http://www.titebond.com/product.aspx?id=e8d40b45-0ab3-49f7-8a9c-b53970f736af
I made my first cutting board 6 years ago using III and have had no issues with it. Assuming you are not planning on submerging your cutting board in water, I suppose you could get away with II. But I’d use III just to be safe. Just a couple dollars more. The added open assembly time of III vs II may also be beneficial when trying to clamp up the amount of pics typical used in a cutting board.
View Mario's profile
Mario
176 posts in 3419 days
#3 posted 05-13-2015 02:26 AM
Jorge, any PVA glue will do fine as long as your board is soundly built. Cutting board life will depend on care and cleaning method involved more than anything else.
View paxorion's profile
paxorion
1107 posts in 2068 days
#4 posted 05-13-2015 02:12 PM
I’ve used both Titebond II and III. Both work fine for cutting boards.
-- paxorion
View SirIrb's profile
SirIrb
1239 posts in 1253 days
#5 posted 05-13-2015 02:13 PM
I use II.
View bonesbr549's profile
bonesbr549
1557 posts in 3090 days
#6 posted 05-13-2015 03:00 PM
I used yellow Elmer s glue on the 1st oak board I made somewhere around 35 yrs ago, its still together, it sits in hot soapy water to get cleaned and drip dries. No cracks splits checks or credit cards, I soak it in mineral oil maybe every 10 yrs or so.
- Ghidrah
Same here. I’ve got the one I made my mom in shop class from 79. I think it was just plain old elmers glue.
Still holding fine and strong after all these years!
View Kyle Nelson's profile
Kyle Nelson
52 posts in 1337 days
#7 posted 05-13-2015 06:39 PM
I’ve used Elmers and am currently testing out Titebond II. So far so good, but I’ve only been making them for a year or so.
View bondogaposis's profile
bondogaposis
4755 posts in 2374 days
#8 posted 05-13-2015 09:55 PM
I always use TB III now. I made my daughter a CB w/ TB II and of course she ran it through he dishwasher and while it still held together it warped bad and looked like it would not survive another trip through the dishwasher. So you never know what will happen to a board once it is out of your hands. I don’t like putting my name on things that may fall apart even if it is through abuse, so now I use TB III on them all. It doesn’t cost more, so why not?
-- Bondo Gaposis
Jorge Velez
#9 posted 05-14-2015 12:34 AM
thank you every one for your comments on this!
my inquiry is due to the lack of water prove glues in Mexico, besides poliuretane glue there are no water prove wood glue, and the only one I can get is tite bond I & II, which BTW is very expensive, and I happen to travel to USA this wk from May-11 to 18 and plan to purchase the glue, but in MEx I cant get it.
again thks for your comments! I’ll try with tite bond II and when able to have acces to III will take advantage.
Ghidrah
#10 posted 05-14-2015 12:37 AM
I don’t know if the one I spoke of is big, normal or small, 1.5625” X 13.5” X 15.5”, but I made a bunch for a guy (30/40) around 06/07, (his design) about 13/16 thick mixed species, (maple walnut oak long grain no end grain) he then used his multi axis router syst. and carved juice grooves, finger grabs and the customers name. He never made a 2nd order, so maybe the skinny weensy boards don’t hold up as well.
View isu1977's profile
isu1977
44 posts in 2896 days
#11 posted 12-12-2017 03:17 PM
I am making cutting boards for Christmas gifts using Tite Bond II. I read where you are not supposed to submerge the cutting board in water or place it in a dish washer because it will soften the glue and thus the board will fall apart. But that said, what will all the oil do to the glue that soaks in. We’re told to apply oil until the boards won’t except any more. Just wondering how this will effect the glue bonding everything together. My cutting boards are an 1 1/2” thick.
-- Cy - Des Moines, IA
View ArtMann's profile
ArtMann
950 posts in 839 days
#12 posted 12-12-2017 03:31 PM
If you soak a wooden cutting board overnight in mineral oil, it probably won’t penetrate even 1/8 inch. It may, however, prevent water from soaking in and dissolving the glue.
View LittleShaver's profile
LittleShaver
326 posts in 642 days
#13 posted 12-12-2017 05:18 PM
The last end grain cutting board I made was about 1 3/4 thick and maybe 12×18 of maple and cherry. Over the course of a week, it soaked up an entire pint of mineral oil. Full penetration, the oil was weeping out the other side. Used Titebond III for longer open time and water resistance.
-- Sawdust Maker
ArtMann
#14 posted 12-12-2017 05:35 PM
That is an interesting claim. Forgive me if I am skeptical but I have done cross sections of mineral oil soaked Maple before and I was unable to ever get penetration in excess of a few 32’s of an inch. Wood is just not that porous. There is a reason why pressure treated lumber must be vacuum and pressure treated to get any amount of penetration.
View AlaskaGuy's profile
AlaskaGuy
4204 posts in 2332 days
#15 posted 12-12-2017 06:24 PM
Yes you can.
Elmer’s yellow carpenter glue is what I have on my 10 year old end grain cutting board. I don’t soak it or put in in the dishwasher
