Designing a Plaque
Forum topic by John R. posted 439 days ago 260 views 1 time favorited 8 replies Add to Favorites
View John R.'s profile
John R.
58 posts in 444 days
439 days ago
As part of a plan to make some plaques to mount my deer anlters, I was wondering if anyone could give me tips on just how I go about getting my plaque design from paper to wood? Actually, I need help getting them on paper too! I know what I want, and can sketch it on a piece of paper, but now it is time to make it the “actual size” I want to use. I took three years of mechanical drawing in high school, and I was thinking of getting some sort of drafting table, or something like that, but don’t know if there is an easier way – perhaps with software, or something? Once I get it on paper to the actual size I want, how can I transfer that to a pattern to use a band saw to cut what I need? Any helpful tips would be GREATLY appreciated.
Thanks in advance!
-- John R. - Richmond, Ohio, "With God, all things are possible"
View Thos. Angle's profile
Thos. Angle
3409 posts in 490 days
439 days ago
On things like this I draw the pattern on Illustration board and cut it out with an Exacto knife. I can sand the illustration board if I need to smooth an edge. I then tranfer the pattern to 1/2 mdf by tracing around it. I then carefully cut this out on the bandsaw and clean up the edge with sanders. Disc and Delta BOSS. I then trace around the template I’ve just created on the real wood. Then I cut the pattern out on the bandsaw leaving about an 1/8 inch all around. I then attach the template with double sided tape to the workpiece and use a pattern routing bit in a router table to clean up the edge and duplicate the template. With all those deer horns this seems like the way to go.
John R.
439 days ago
So, the illustration board is basically a large piece of thicker type of paper? Or is this very thin wood…?
Thos. Angle
439 days ago
Illustration board is a special art cardboard which is availabe in art stores. It is made for drawing with pencils or pens. You could do the same thing with poster board but it isn’t dense enough to make a good pattern. I always have it in the shop to do patterns for the saddle shop. I can then draw a carving pattern right on my cut out pattern. The advantage is that it will hold up to repeated tracing around on work pieces. For your purposes get the cheapest.
John R.
439 days ago
Excellent, I will get my hands on some ASAP. Sounds like it will be needed again and again. Thanks for the help!
View jockmike2's profile
4437 posts in 774 days
439 days ago
If you check out my latest project I posted John, I did a Euro mount a few months ago using oak burl and a polymer epoxy. I run the burl through the planner and got it smooth then poured on the epoxy, then mounted the antlers. Very fast and easy, and cheap. jockmike2
-- Mike. Profisher50@yahoo.com
438 days ago
example of deerhead mount
John R.
438 days ago
Michael, that’s quite the mount! Thanks for sharing it. I think the rack looks much better than a clock!
View Woodminer's profile
Woodminer
69 posts in 465 days
425 days ago
Hey John R,
Sorry I’m late to the party on this one.
I note that you’re planning to cut your plaques on a bandsaw. If you “draw” or scan your plan into your computer, and presuming that you have access to a printer, you can always just print out a new one. Glue it on with spray glue and cut ‘er out. Works the same with scroll saw type patterns.
Nice thing about this is that you can add any instructions or notes to yourself that you’d care to keep. Router bit # that you’ve used to finish the edge, grain direction that particularly appealed to you, finishes that worked or didn’t, any number of things.
And, if you are a good computer user, you back up your files occasionally to a CD or DVD so that when the inevitable happens, you still have your records. That and a paper backup in your files. 8^)
-- Dean, Missouri
Bookmark And Share This Page
