Minwax Polycrylic on top of Polyurethane?
Forum topic by petscontained posted 08-17-2009 09:10 PM 4230 views 0 times favorited 2 replies Add to Favorites Watch
View petscontained's profile
petscontained
1 post in 3169 days
08-17-2009 09:10 PM
Topic tags/keywords: polyurethane sealant polycrylic cornhole board sealing
Started a simple project of building a set of cornhole boards for my nephew.
Built the boards, 2 coats of white primer. 3 coats of paint, and 3 coats of Polyurethane.
I purchased 2 Ohio State emblems to afix to the boards, and then I was going to cover with another 2 coats of polyurethane.
I now see that the directions from the emblems specifically state not to use polyurethane or any other oil base sealant. It says to use a Minwax Polycrylic.
Is it safe to apply one coat of a minwax polycrylic on top of my polyurethane, then place the emblem on that. Then cover with the minwax polycrylic?
Will I have problems between the polyurethane and the minwax polycrylic?
Thanks for any help.
2 replies so far
16274 posts in 4183 days
#1 posted 08-18-2009 01:31 AM
I’ve never tried it, but the general rule is never mix oil and water-based finishes.
13600 posts in 3306 days
#2 posted 08-22-2009 04:00 PM
ditto with above ,
don’t drink and drive !
clean off the polyurethane ,
then use the polycrilic only .
