Anchorseal
Forum topic by Innovator posted 101 days ago 237 views 0 times favorited 6 replies Add to Favorites Watch
View Innovator's profile
Innovator
3125 posts in 310 days
101 days ago
Topic tags/keywords: tip question lathe turning
Has anyone used anything other than Anchorseal to seal the edges of logs to prevent cracking? I have heard of people using old paint, varnish, etc. but I am not sure of the results. Before giving it a try I wanted to see if anyone had been using anything other than the anchorseal.
-- Whether You Think You Can or You Think You Can't, YOU ARE RIGHT!!!
View PurpLev's profile
PurpLev
2762 posts in 545 days
101 days ago
Latex paint should work well. I personally would not use varnish as it also penetrates the wood. but then again – if you have lots of extra, might as well put it to use.
View John Gray's profile
John Gray
1755 posts in 782 days
101 days ago
I use white latex paint….white because you can date the wood on the white with a Sharpie and have a record of when it was put up to dry.
View jockmike2's profile
7328 posts in 1143 days
101 days ago
I’ve used old cans of spray paint of whatever I had, didn’t matter what. Just to get it covered. Seemed to never fail. I’ve got some wood 3 years old with spray enamel and they still haven’t cracked. I still like anchorseal.
-- Mike. mwurm13@yahoo.com
View jack1's profile
jack1
382 posts in 924 days
101 days ago
Yes to the above. What ever you have that won’t penetrate too far.
-- jack -- measure once, curse twice!
View Pooky's profile
Pooky
5 posts in 173 days
100 days ago
I’ve used Pentacryl. The only draw back is, that it really use alot of it to do the job.I tried it cause it was more green friendly.
View dirtclod's profile
dirtclod
165 posts in 757 days
100 days ago
The goal is to reduce moisture from leaving the end of the log. If you are going to use paints, use paints that are formulated to stop moisture penetration. (Exterior paints are formulated to let any moisture that penetrates excape so it doesn’t rot the wood.) Look for mis-matched colors for bargains.
Bees wax is by far the premium log end sealant. But it comes at a cost.
Parrafin wax (a.k.a. gulf wax in the canning section of department stores.) works well. Use a double boiler and keep away from open heat sources as this stuff is very flamable. FYI – Anchorseal is an elmulsification of parrafin and water…
-- Wonderful new things are coming! - God
