looks like a bench mounted draw knife to me...
Forum topic by rf58 posted 103 days ago 367 views 0 times favorited 6 replies Add to Favorites Watch
View rf58's profile
rf58
5 posts in 108 days
103 days ago
I was at an auction the other day and I bid on a tool up to 65 $. Not real sure IF it was a woodworking tool or not…….. I will try to describe it..
First of all I would call it a bench mouted draw knife .??
It was about 6 “ wide with a FIXED DRAW KNIFE LIKE blade facing away from you!
Underneath a 7/8” (ADJUSTABLE up and down) ROLLER.. ( like for the depth of cut….) with finger screws….
ALL CASTED IN TO ONE SOLID UNIT made to fasten to a bench / table = A casted ANGLE IRON base about 2” DOWN AND 2” BACK. A factory made unit.
IN front when you looked at it , inset were 2 thin metal straps running outward from the center only about 5/16 wide ..??
IT LOOKED TO ME LIKE YOU WOULD PUT A PIECE OF WOOD ,BRANCH OR SOMETHING AND PULL IT TWARDS YOU = THE ROLLER WOULD STOP IT FROM GOING TO DEEP.
DOES ANY ONE KNOW WHAT I SEEN.
-- rf58, Illinois
View PineInTheAsh's profile
PineInTheAsh
195 posts in 166 days
103 days ago
Greetings rf,
Welcome to LJ, you’re gonna like it here.
Bidding at auction for something you know little or nothing about, mmm.
You can send $65. checks over here anytime. I’ll even reimburse postage.
In trying to translate even your excellent description, the old saying must be invoked: One picture is worth a thousand words.
Look forward to reading your comments and seeing your projects.
Cheers and all the best,
Peter
View Toolz's profile
Toolz
307 posts in 640 days
102 days ago
Sound like a bench mounted leather skiver to me. Used to thin belt strips etc.
-- Growing older but not up!
View rf58's profile
rf58
5 posts in 108 days
102 days ago
Glad to see you took the time to respond. I don’t mind advice on my wood working but not on how or what I spend my money on. If I had a picture I would have sent it. I took a lot of time writing up the description . That was the best I could do.
-- rf58, Illinois
View mics_54's profile
mics_54
432 posts in 369 days
102 days ago
http://www.csosborne.com/no86.htm
This is a leather splitter. It might be what you saw.
-- Dan, Sterling Alaska, http://sullcon.homestead.com/ Before you criticise some one, walk a mile in their shoes...then you will be a mile away and you have their shoes!
View rf58's profile
rf58
5 posts in 108 days
102 days ago
that is what it was A LEATHER SPLITTER === THANK YOU VERY MUCH
I THOUGHT I NEW EVERYTHING ———- BUT IM STILL LEARNING THANK YOU AGAIN
-- rf58, Illinois
View rf58's profile
rf58
5 posts in 108 days
102 days ago
Splitting Machine
Osborne No. 86 – $556.98
This solid splitting machine is the most professional marketed. It has a sturdy cast iron frame. A hollow ground 6” blade is forged of two pieces of steel or inlay instead of steel. Easy fine tuning adjustment for even splitting of any thickness of leather. Instruction sheet provided. For the true professional.
Weight ea
(lbs) UPC No.
7 17052
WELL I SEE WHY IT WENT SO HIGH.
-- rf58, Illinois
