What is considered "A General Rule of Thumb" ?
Forum topic by ericandcandi posted 100 days ago 647 views 0 times favorited 21 replies Add to Favorites Watch
View ericandcandi's profile
ericandcandi
84 posts in 413 days
100 days ago
Topic tags/keywords: question tip
I am relatively new to this wonderful world of woodworking and got to thinking one day. Alot of us noobies out here do not have a construction/woodworking background in any way. No matter how many books and magazines we read, there is know way we can learn all of the ”basicrules of thumb that woodworkers have learned either in their field of expertise or that have been passed down from generation to generation. The question that started all of this is:
When using standard woodscrews, is there a correct bit size to use for pre drilling? Is there a general rule of thumb for the correct undersize drill bit for each size woodscrew used?
Wouldn’t it be great if there was a thread/forum /posting/sticky or something that those of use new to woodworking could go and be that much further with our woodworking knowledge?
Please feel free to leave your best General Rule of Thumb…( about woodworking! )
-- ericandcandi, Louisiana- Home of the "LSU Tigers"
TopamaxSurvivor
3027 posts in 571 days
100 days ago
My first rule of thumb is to try not to hit it too many times a day ;-)))
View scrappy's profile
scrappy
1618 posts in 325 days
100 days ago
First and formost rule of thumb…....
If it looks dangerous, DON’T DO IT! Saftey first!
-- Scrap Wood's the best...the projects are smaller, and so is the mess!
View JuniorJoiner's profile
JuniorJoiner
166 posts in 335 days
100 days ago
i’m with scrappy, if it looks unsafe don’t do it. use pushsticks and the machines guards. control dust so your not breathing it. and wear eye protection. everything in woodworking comes with or from experience; I hope you have no bad ones.
I do most of my woodworking without power tools, so I use chisels more than most.
here is my blurb on chisels .
when buying chisels, it is all about the steel. fine grained steel . hard and capable of taking a fine polish is essential. good chisels will lead a long life, be rehandled many times, passed on to generations . and even reground or repurposed when worn down.
cheap chisels are not worth the tin cans they are made from. coarse grained steel that won’t take an keen edge, dull quickly, or even bend after some mallet work.
worse, cheap tools can cause a beginner to doubt their abilities, both with sharpening or using them.
handles are not quite as important when selecting a chisel, as they are made of wood, and can easily be modified by the user. they should be comfortable to use, suited to the task the chisel is meant for, and not so round as your chisel rolls off your worksurface when you lay it down.
important to add, as with all tools. a dull cutting tool is useless. investing in the tool is equally as important as investing in the stones and skills to sharpen it.
using chisels
there are many different types of chisels, some general purpose. many specific to certain tasks.
in general, all chisels are used mostly the same way.
chisels only have one handle but are usually a two handled tool. one hand to provide the cutting force(on the handle)and the other to guide the cut(closer to the cutting edge)
the face of the chisel (the beveled side-a chisel is only beveled on one side) should be the face you can see during use. if you see the flattened back of the chisel, you are using it backwards, and have less control of it’s cutting action. cutting mortise’s is an exception.
guide blocks are an invaluable asset to chisels.helping the woodworker maintain the proper angle for paring or chopping cuts. they also enable repeatable accuracy.(ie. paring all your dovetails to a perfect 90 degrees.)
nearly all fine joinery is best created with a chisel and appropriate guideblock.
sidenote- guideblocks are easily created accurately with an electric mitre saw. just remember that with the scale on a mitre saw, 0 is actually a 90 degree cut.
also when creating guideblocks, remember to leave length so they can be clampled to the workpiece.
take small bites. chisels drift away from their beveled face when you apply force. this is lessened when the bevel encounters less wood. so by taking small bites you improve accuracy, also lessening the chance of breaking or splitting the workpiece.
what i have written is certainly not gospel, as I am no expert.(as a matter of fact I have lots of trouble sharpening carving chisels)
I just hope it helps some.
good luck.
-- Junior -Quality is never an accident-it is the reward for the effort involved.
View Gary Fixler's profile
Gary Fixler
647 posts in 277 days
100 days ago
Something about wood that impressed and surprised me as a newb (still not far from that distinction) was the concept of wood movement, and how very alive wood remains long after its been felled, sawn up, and dried. Just search Google for “wood movement” and you get 137k pages on the subject. Just the first few are enough to learn a lot about it, and there’s even a handy calculator from one of my favorite online wood shops. Wood moves a lot across its grain, and almost not at all with the grain (something like 0.1% on average). The way the wood is resawn matters, too, so learn a bit about plain sawn/flat sawn (most movement), quartersawn (less movement), and riftsawn (least movement, least available (hardest method of resawing)). There’s also an element of aesthetics in each of these. Sometimes you just want the cathedrals seen in plain sawn lumber. Sometimes you want the thin, consistent stripes of quartersawn.
Some anecdotes I’ve heard about wood movement include tables cracking loudly in half down their lengths, right through the center, antiques that have been fine in antique shops and homes in one place for 100 years being purchased and brought to another place only to have the change in humidity cause them to warp, bow, twist, and crack, and I’m on the list of having a lot of my projects fail months later, because I didn’t properly appreciate how very much wood moves. I’ve made things that slide easily enough when made bind completely later – beyond any mechanical means of moving them ever again – because I made things that should slide fit too perfectly together. I was even proud of my perfect fits :)
I turned a Eucalyptus cup on my lathe with a base exactly the diameter of the faceplate it was screwed to, even sanding it and the faceplate a bit when finishing it – they were flush. A month later the cup was nearly 1/8” shy of the faceplate all the way around, or nearly a full 1/4” thinner, and it was only about 3” wide to begin with! In fairness, it was made from a fairly green limb, but still, I was shocked when I saw it sitting there on my workbench.
Things like rail-and-stile cabinet doors came about because the panels inside need room to grow and shrink inside the grooves in the rails and stiles. I didn’t know this earlier this year and glued some pretty poplar panels into their frame grooves. I’m worried that if I ever move, those doors are going to crack all over in their new home.
Oh, and one last thing about this – good woodworkers tend to buy the wood they need for a project, then stack it up in its final location for a few weeks to let it acclimate to that location. Some even leave it in a kitchen where it’s destined to become cabinets, or upstairs in an office boardroom for a month, then go pick it up when they’re ready to build. They’ll mill the wood (cut, rip, plane, etc) and assemble everything ASAP. It’s not good to cut up all your pieces, then leave them sitting in your shop for a week before you get back to assembling. They’ll warp again, even if just a little bit. Fit won’t be as perfect. For a lot of things it’s okay, but if you want really perfect, pro-level work, they tend to follow these steps religiously.
-- Gary, Los Angeles, video game animator
View firecaster's profile
firecaster
482 posts in 313 days
100 days ago
ericandcandi,
Concerning your question about predrilling for woodscrews; the easiest thing is to find a chart from a magazine or maybe online that shows drill sizes for screws. If you use a countersink, it is sized for a particular diameter of screw. If all else fails, I hold the drill bit and screw together and make sure the drill bit is the same size as the shank excluding the threads. That allows the thread to have full bite into the wood.
As for drilling a hole the screw will fit through, I just remember from my hardware store days that #6 = 1/8”, #8 = 5/32”, #10 = 3/16”, #14 = 1/4”.
Somebody else may know a better way.
-- Father of two sons. Both Eagle Scouts.
View Jim Crockett's profile
Jim Crockett
322 posts in 628 days
99 days ago
Wood Magazine has a useful woodscrew pilot hole chart.
Search for screw chart and you’ll find many more.
Jim
View KnockOnWood's profile
KnockOnWood
36 posts in 110 days
98 days ago
The internet has loads of info, tips & tricks, but don’t underestimate your local library. Mine in Baton Rouge has at least ten shelves worth of woodworking/furniture building books.
Good Luck!
Joey
-- Joey C., Baton Rouge, LA --- Carpenter, Attorney, Procastinator
ericandcandi
97 days ago
Thanks for all of the great comments!!!!!
16841 posts in 472 days
97 days ago
As someone once said”to read understand and follow all of your tools instructions and most important of all wear you saftey glasses
View floyd3's profile
floyd3
6 posts in 97 days
97 days ago
My wife bought me a book last Christmas called “Woodworker’s Essentials”. It taught me all sorts of things I didn’t know. Here’s a link for purchase
http://www.dealoz.com/prod.pl?cat=book&op=buy&lang=en-us&search_country=us&shipto=us&cur=usd&zip=&nw=y&class=&pqcs=oUzCqfgchiZ0HLECSiNThg&quantity=&shipping_type=&sort=&data_id=540073
-- "The definition of insanity is doing the same thing over and over again and expecting different results." A. Einstein
View papadan's profile
papadan
458 posts in 263 days
97 days ago
I built my web site to answer questions like yours. On my home page, click on the INFO button and you will find screw size, drill bits, and all kinds of information you can use. Example is the pilot hole chart here. http://www.hoistman.com/HoistMan/PILOT.html
-- Dan-- Info for all @ http://www.hoistman.com
View Gene Howe's profile
Gene Howe
334 posts in 323 days
96 days ago
a1Jim,
Who was that guy?
-- Gene
scrappy
95 days ago
Got this in an E-Mail today along with some other “Little Known Facts”
In the 1400’s a law was set forth in England that a man was allowed
to beat his wife with a stick no thicker than his thumb.
Hence we have ’the rule of thumb’
View sIKE's profile
sIKE
1094 posts in 649 days
95 days ago
My main rule of Thumb? Don’t do this to your thumb!
Courtesy of Degoose!
Gary Fixler
95 days ago
sIKE – Now that is nasty. First guess: circular saw? Second guess: band saw?
View sIKE's profile
sIKE
95 days ago
That is not my thumb..as I have followed my rule of thumb…that is Degoose’s thumb, check out his day 2 blog on his 150 cutting board thread…...
View scottishrose's profile
scottishrose
84 posts in 61 days
21 days ago
The origional Rule of Thumb from which everyone uses the term incorrectly is: A man can beat his wive with a stick no larger than his thumb. I say it’s time to retire the “Rule of Thumb” and start a new term for whatever we use it for unless people here are mysogonistic – not calling anyone this by the way. Just trying to educate people that the term is about abuse, not general knowledge rules that folks should followor know.
View vonhagen's profile
vonhagen
124 posts in 57 days
21 days ago
safety first, then buy a starrett 6 inch no 604r rule and learn the first inch right down to the 64th scale.
-- blaine von hagen
View Roger Clark's profile
Roger Clark
210 posts in 330 days
21 days ago
Rule of thumb is what a destitute woodworker uses because he can’t afford a ruler.
-- Roger, Rep. of Texas
TopamaxSurvivor
21 days ago
That’s a good rule scottishrose. We wouldn’t want to see any Lady Jocks with broken bones:-))
View cowdog80's profile
cowdog80
32 posts in 42 days
21 days ago
Rules of thumbs are great until somebody finds a new way to screw something up.
- Behlen
- Waterlox Inc.
-- http://woodworker.com
