UHMW for inserts?
Forum topic by MedicKen posted 08-17-2009 12:44 AM 3629 views 0 times favorited 9 replies Add to Favorites Watch
View MedicKen's profile
MedicKen
1615 posts in 3490 days
08-17-2009 12:44 AM
Has anyone ever tried to make a zero clearance insert for their table saw from UHMW? I have a sheet of 3/4”x4” and need an insert for my unisaw. I have a factory, pot metal, dado insert that was with the saw when I found it in the scrap heap. I know I can use plywood but I thought I would give this a shot as well.
9 replies so far
13609 posts in 3369 days
#1 posted 08-17-2009 12:55 AM
never had heard of it ,
so i just googled it ,
says high resistance to abrasion .
can it be cut ?
or shaped ,
without special tools ?
if so why not ,
you cut aluminum with woodworking tools .
35125 posts in 4429 days
#2 posted 08-17-2009 12:57 AM
It would work. But you might find a better use for it than as a zero clearance. Lots of other materials could be used for zero clearance blade inserts.
View marcb's profile
marcb
768 posts in 3701 days
#3 posted 08-17-2009 01:56 AM
It’s my understanding that it will work OK, but not terribly stable when unsupported. So if you remove it it may have warped if not stored flat.
On the other hand get yourself some aluminum and make the Cadillac of inserts.
http://www.woodcentral.com/articles/shop/articles_893.shtml
MedicKen
#4 posted 08-17-2009 02:19 AM
David…I have been using it for jigs and router sets up for some time. It can be cun and machined with wood working tools without a problem.
Marc…..you gotta be joking….lol….There is no way I am gonna subject my router bits and bandsaw blades to that.
marcb
#5 posted 08-17-2009 02:44 AM
Aluminum machines well with carbide, no joke. Its not too hard on it either.
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3741 days
#6 posted 08-17-2009 02:51 AM
I have cut a few T-slot channels with my compund mitre saw, doesn’t seem to do the carbide any harm and it cuts a nice square clean cut. If I were machining it more I may lubricate it with vinegar (I don’t know why it works but it sure does).
View John 's profile
John
253 posts in 3430 days
#7 posted 08-17-2009 03:01 AM
Ken, I’ve been using UHMW for inserts for years, no warp, no vibration, EXCELLENT material to work with. Recently I made one from some left over Corian, that works great as well.
John
-- John
#8 posted 08-17-2009 03:06 AM
John: I hadn’t thought of Corian. That would be a great choice. I’ve got a bunch of that. And it glues easly.
View PurpLev's profile
PurpLev
8536 posts in 3677 days
#9 posted 08-17-2009 03:11 AM
UHMW, although might work for some – is not the most stable material of the bunch. I would personally shy away from it for inserts. it’s a good material for it’s smoothness, but has to be bolted down to keep it’s flatness (TS fences, miter sliders, jigs, ... you get the point – screwed/bolted to another stiff flat surface), I dunno – for the size of an insert – maybe there really is no big chance of warping. but I’d personally rather not ever have to worry about it.
