three angled boards
« back to Joinery forum
Forum topic by Louis Petrolia posted 05-10-2015 03:50 PM 990 views 0 times favorited 17 replies Add to Favorites Watch
View Louis Petrolia's profile
Louis Petrolia
28 posts in 1830 days
05-10-2015 03:50 PM
I have 3 angled 3/4” pieces of plywood at approx. 22” high x 12” wide.
first piece angled at 30 dgrees left side and 15 degrees right side. One middle piece is angled
at 15 degrees both sides, and third piece angled at 15 degrees left side and right side 30 degrees.
Any suggestions how to clamp and glue these 3 sections. I do not have a kreg pocket hole jig.
Some suggestions about brad stapler etc. Very difficult with these angles. I have tried blocks cut
to these angles to clamp. No. luck. Haven’t started the cabinet just yet until I hear your suggestion.
I have never used a Kreg Poket hole jig either.
certainly could use some expert advice and help in my dilemma.
Thanks
LOUIS PETROLIA
17 replies so far
View jerryminer's profile
jerryminer
923 posts in 1438 days
#1 posted 05-10-2015 05:25 PM
I THINK you are talking about an arrangement like this pic (flat angles, not beveled edges). Tack together some scraps to get a place for clamps to get a good purchase.
View RogerM's profile
RogerM
792 posts in 2396 days
#2 posted 05-10-2015 05:39 PM
Louis – From your description I have no idea of what you are trying to clamp up. A few pointers that might help though:
First, butt joints rarely work very well for plywood. If you are doing butt joints some splines or biscuits will help in securing a joint of reasonable strength.
Second, If you are doing butt joints, some fine dry sand sprinkled on the glue between the joining surfaces will reduce the slippage and help in clamping procedures.
Third, If you are going to do some cabinetry invest in one of the more inexpensive pocket hole jigs such as http://www.rockler.com/mini-kreg-jig-pocket-hole-kit. It will save you a lot of grief and time and will pay for itself in a short amount of time.
I hope this has been of some help. Good luck on your project.
-- Roger M, Aiken, SC
Louis Petrolia
#3 posted 05-10-2015 06:35 PM
Thanks Roger
This is not what I am looking for. I am looking for beveled edges. You will note that I indicated the
different degrees on the edges of the 3 pieces. Not angles as you have shown. Sorry I am not too
clear. I do not know how to show a sketch as you indicated. I am not a computer guru. If I was
able to show you, I could sketch a top view to show you the beveled joints as previously indicated.
Thanks again Roger
LOUIS
View waho6o9's profile
waho6o9
8190 posts in 2574 days
#4 posted 05-10-2015 06:43 PM
Please sketch a top view Louis, thanks.
I’m guessing it’s a base of some sort?
Louis Petrolia
#5 posted 05-10-2015 06:53 PM
Sorry waho609 As I indicated to Roger. I do not know how to sketch on the computer. I am not that
great on the computer. I can only do basics. Rockler.com shows a curved view with a Kreg pocket hole
jig. Gives you an idea what I am talking about.
LOUIS PETROLIA
waho6o9
#6 posted 05-10-2015 06:56 PM
Just sketch it on paper
waho6o9
#7 posted 05-10-2015 07:16 PM
Something like this?
Louis Petrolia
#8 posted 05-10-2015 07:21 PM
waho609
It is not a base. This is a cabinet. As indicated each piece is 12” wide x 22” high. You are showing
a basic joint using angled cuts which is not exactly what I am asking. I am using authentic butt joints
similar to a joint you would use if something was 30 degrees and two boards to match up properly
would be 15 degrees each. That is an authentic bevel. It is basically a corner type cabinet with
angles in the rear of the cabinet.
Thanks anyway guys. I have searched over the internet for this info. Cannot find any info at all
where someone understands this type of jointing.
LOUIS PETROLIA
waho6o9
#9 posted 05-10-2015 07:27 PM
View Daruc's profile
Daruc
460 posts in 1130 days
#10 posted 05-10-2015 08:03 PM
Cut your angles, lay them flat and put them together with the points touching each other. Use 2 or 3 strips of masking tape down the seam. Turn the pcs over, put glue into the joints, then close them up. Your tape will be the clamp. All you have to do is run some tape or a clamp from side to side to keep your joint from coming back open until your glue dries.
I’ve never done this myself, but I heard it works real good if you do it right.
https://www.youtube.com/watch?v=wvxLCfnw4YQ
View AlaskaGuy's profile
AlaskaGuy
4133 posts in 2306 days
#11 posted 05-10-2015 09:39 PM
I’m confused. Does angled mean mitered?
View Kazooman's profile
Kazooman
1006 posts in 1949 days
#12 posted 05-10-2015 09:45 PM
There seems to be a lot of confusion as to just what Louis is trying to glue up.
Drawing skills aside, a picture is worth a lot. How about propping up the pieces approximately like they need to be, or getting a helper to hold them, and taking a picture? If you post one I bet you will get several good solutions for your problem.
AlaskaGuy
#13 posted 05-10-2015 09:45 PM
I ve never done this myself, but I heard it works real good if you do it right.
- woodust
That technique is commonly called “miter folding”.
jerryminer
#14 posted 05-11-2015 12:21 AM
One more try. Are you making something like THIS pic?? You should still be able to put together some clamping blocks from scrap. Splines will also help.
waho6o9
#15 posted 05-11-2015 12:29 AM
jerryminer for the win!
