Pocket holes in corner braces
Forum topic by tolmeda posted 105 days ago 372 views 0 times favorited 5 replies Add to Favorites Watch
View tolmeda's profile
tolmeda
5 posts in 105 days
105 days ago
Topic tags/keywords: pocket hole table question joining
First post here… I’m new to woodworking and finishing up my first project, a bedside table. I’m planning to post about what I learned and what I screwed up but first a quick question to help me finish up this project.
I’d like to add corner braces to attach the top but can’t quite figure out the best way to join them to the frame. I’ve got the four 6” pieces cut and mitered at 45 degrees. The rest of the joints on the table so far are a combination of dowels and pocket holes. My pocket hole jig, the really basic Kreg one, doesn’t work so well on the 45 degree angles.
Any tips on how to best attach these?
Thanks!
View Gary's profile
Gary
597 posts in 331 days
105 days ago
I do those on the drill press
Welcome to LJ’s
-- Gary, DeKalb Texas
View bent's profile
bent
38 posts in 567 days
105 days ago
drill the pocket into the top(the side that contacts the bottom of the tabletop) of the bracket on each side, not the angled edge. that way you can be perpendicular to the sides. once the top is on, it will hide the pocket holes.
View notottoman's profile (online now)
notottoman
478 posts in 129 days
105 days ago
Make sure as well that you are away from the corner. Leave at least a minimum of 5 mm. before the corner join. This allows for a bit of play.
What I do is glue the 45deg cuts and panel nail it to the frame. once firm I can then go in and drill pilot holes to secure it properly. then drill a hole to screw to pull the top down to the corner braces.
-- "Even small steps makes a distance." (Shawn Phillips, musician)
17049 posts in 475 days
97 days ago
Pocket hole the ends first then cut the angles
notottoman
97 days ago
Like they say “why did’nt I think of that.
Thanks a1Jim. You know, I do do things like that. Some of the time. I must instill it in me as a habbit.
Thanks for the reminder.
