Help choosing 4" angle grinder tool for power carving
« back to Woodcarving forum
Forum topic by Planeman40 posted 05-09-2015 01:30 PM 1337 views 0 times favorited 6 replies Add to Favorites Watch
View Planeman40's profile
Planeman40
1102 posts in 2667 days
05-09-2015 01:30 PM
Topic tags/keywords: carving tool question carving shaping
I am looking at buying a tool to fit onto my 4” angle grinder for power carving and hollowing out. I see two types, one is a bit of chain saw chain around a disk, the other are shaped burrs with little spikes on them. There may be others that I am not aware of. I would like to get some advice regarding the pros and cons of each design and what are the better ones to buy.
Planeman
View waho6o9's profile (online now)
waho6o9
8100 posts in 2483 days
#1 posted 05-09-2015 03:37 PM
http://www.arbortechusa.com/view/woodworking/
I like the one above but haven’t purchased it yet and am curious to
the responses on said inquiry.
View ksSlim's profile
ksSlim
1269 posts in 2796 days
#2 posted 05-09-2015 09:20 PM
Arbortech! They sell different levels of teeth/blade set for different finish.
Corase does a fine job for roughing in. Med or fine cleans up the tool marks.
-- Sawdust and shavings are therapeutic
View ClaudeF's profile
ClaudeF
591 posts in 1614 days
#3 posted 05-09-2015 11:25 PM
I bought this one http://www.woodcarverssupply.com/45-NUGGET-WHEEL-X-COARSE/productinfo/264045/ to convex curve roughing. It does fairly quick work, but I don’t think I’d try it on any hollowing in inside curves. This one might be useful for inside curves http://www.woodcarverssupply.com/4-COARSE-DONUT-WHEEL/productinfo/259882/
The Arbortech Turboplane or mini-turbo both look like they would work well, and the mini specifically mentions deep internal profiles http://www.arbortechusa.com/view/woodworking/mini-turbo/
-- https://www.etsy.com/shop/ClaudesWoodcarving
View Quanter50's profile
Quanter50
278 posts in 2203 days
#4 posted 05-10-2015 02:12 AM
Harbor Freight has the “Lancelot 22 tooth carving disc” I have used this on my angle grinder a few times. They are fairly easy to use. They hog off the wood well. http://t.harborfreight.com/22-tooth-carving-disc-7697.html?utm_referrer=direct%2Fnot%20provided
Planeman40
#5 posted 05-10-2015 09:43 PM
Thanks guys.
It appears as if I might need two wheels, one of each type. I like the chain saw type as I can sharpen the blades and I know it can give be an acceptable finish to sand down further. It appears it would be a touch limited in getting into smaller recesses. And the Harbor Freight one is the same make as Woodcraft but $15 cheaper. I think I’ll try this one first and see where it takes me. The “spikey” types come in various “grits”. It might be that one of these would be helpful for finishing out a hollow form. If I find I need one I believe I would get one with a less aggressive “grit”. None of these things are cheap. : )
View rick1955's profile
rick1955
264 posts in 1337 days
#6 posted 05-11-2015 11:09 AM
http://www.arbortechusa.com/view/woodworking/industrial-woodcarver/
The arbortech industrial wood carver would my choice. I already most of the brands listed and more. The carbide discs last ten times longer than steel and can be rotated for a fresh edge. It also gives a nicer finish than the grit type or chain saw wheels.
-- Working smarter with less tools is a true crafts person...
