Shopvac removable dust bag
Forum topic by taidsturning posted 101 days ago 388 views 1 time favorited 11 replies Add to Favorites Watch
View taidsturning's profile
taidsturning
89 posts in 289 days
101 days ago
Topic tags/keywords: trick tip jig shopvac
I would like to fit my shopvac with a plastic bag liner. Without some type of device to hold the bag against the inside of the shopvac I find the bag everntually sucks up around the filter and suction stops.
Any ideas for a simple device which I could remove, then remove the bag, put in another bag and reinsert the holding device and start again?
-- Bill Roberts -- Steal one idea it's called plagerism. Steal a bunch - it's called research
View Bureaucrat's profile
Bureaucrat
7236 posts in 546 days
101 days ago
use hardware cloth (wire with squares welded in it to make it appear like really coarse screen). cut it to about 1” from the bottom of the inlet and use enough of it to equal the circumference of the vacuum. put it in the bag and slip the bag in the vac. When it’s time to empty, pull out the hardware cloth to use with the next bag.
-- Gary, South Central Wisconsin. So much to learn, so little time!
View Bryon McGowan's profile
Bryon McGowan
28 posts in 140 days
101 days ago
I have been useing a shop vac brand vacuum for many years and use the bags made for that vacuum without any problems. I have never had one come of the only problem that I had was when I forgot to change the bags I remember to change the bags now. A pac of bags cost about 10.00$ for a pac of three I hope this helps
-- God is great beer is good and people are crazy
View Blondewood's profile
Blondewood
97 posts in 238 days
101 days ago
I read a tip where you used a regular trash bag, held on the top with a strip of plastic laminate like you would use for a counter top. I guess any thin strip that would fit in the vac and create a ‘clamp’ effect would work, like a piece of matal with a bit of ‘spring’ to it.
View DaveR's profile
DaveR
1521 posts in 614 days
101 days ago
I put a plastic garbage bag in my shop vac and then throw a scrap hunk of wood in the bottom. I also have a thin strip of wood that was ripped off something a long time ago that I bend around and slip into the bag. The spring tension forces the bag to the outside. I suppose the strip of laminate would do the same thing.
-- Until you spread your wings, you'll have no idea how far you can walk.
View Chris Wright's profile
Chris Wright
360 posts in 375 days
101 days ago
I’m with Dave, I’d just throw a chunck of something in the bottom of the bag. Eventually, as it startes to fill the weight of the chips and dust should hold the bag down and out.
-- "At its best, life is completely unpredictable." - Christopher Walken
View oldbill's profile
oldbill
1 post in 98 days
98 days ago
I put a bucket inside the shop vac and the plastic bag inside the bucket. Works.
-- Bill, land o llakes, fl
View Bill White's profile
Bill White
111 posts in 854 days
97 days ago
$10.00 for 3 bags?? Somebody’s smokin’ sompin.
Bill
16769 posts in 471 days
97 days ago
I do what Dave R does.
View Bothus's profile
Bothus
228 posts in 70 days
40 days ago
I have a Rigid shop vac I never use a bag just the filter. What am I missing?
Bothus
-- Professional kitchen designer, amature woodworker.
DaveR
40 days ago
Bothus, you might not be missing anything. I put a bag in the shop vac so I don’t have to dump the thing out when it is full. I remove the lid, dig out that long springy stick, tie up the back and pull it from the vac. No muss no fuss.
View RobFisher's profile
RobFisher
12 posts in 90 days
40 days ago
I have used the shopvac brand bags in my shop vac, especially for drywall dust and the like, they are great. They act as another filter so the shop vac does not blow the dust back out. As mentioned though they are a bit expensive.
I will have to try the plastic bag trick, sounds much better than trying to empty the can, that can be a real pain.
-- Lancaster, PA
