Do I add hinges or finish box first?
Forum topic by TX_1234 posted 05-08-2015 10:35 PM 751 views 0 times favorited 4 replies Add to Favorites Watch
View TX_1234's profile
TX_1234
4 posts in 1349 days
05-08-2015 10:35 PM
Topic tags/keywords: hinges
Hi,
I am building a small hinged box and don’t know if it is best to install the hinges before or after finishing the wood. If I install after finishing, then I’d have to resand/refinish if the box is out-of-alignment once the hinges are installed. If I install hinges before finishing, then I can always sand the lid/box flush at the edges, but the sanding/finishing is cumbersome because I don’t want to damage/torque the 90 degree small hinges too much. Any suggestions?? Do I sand/finish part of the box, then do the hinges, then sand/finish the rest?
View gfadvm's profile
gfadvm
14940 posts in 2924 days
#1 posted 05-09-2015 12:08 AM
Install the hinges, tweak the fit to perfection, remove the hinges, finish, reinstall the hinges. OR Use wooden hinges!
View jsuede's profile
jsuede
69 posts in 1458 days
#2 posted 05-09-2015 12:11 AM
Only made a few small boxes, but I always installed all hardware, then removed it for finishing. Never sprayed, always wiped on finish, so spraying may cause problems refitting hardware if not masked/or mortises cleaned out properly.
View ric53's profile
ric53
194 posts in 1754 days
#3 posted 05-09-2015 12:11 AM
Like gfadym said. LOL
-- Ric, Mazomanie
TX_1234
#4 posted 05-09-2015 05:51 PM
Okay, thanks for your replies. I will be installing the hinges in a few minutes here so I hope it goes okay
