Delta 34-670 table saw went dead, need advice
Forum topic by Lloyd Davies posted 106 days ago 458 views 0 times favorited 9 replies Add to Favorites Watch
View Lloyd Davies's profile
Lloyd Davies
84 posts in 225 days
106 days ago
Topic tags/keywords: tablesaw
I was cutting some 2 inch thick purpleheart with my table saw and all of a sudden it went dead. I turned it off at the switch and extracted the partially cut wood and when I flip the switch again it won’t even start; no noise, nothing. I checked to see if it was a mains fuse or a problem with the socket but it is not.
Can anyone suggest what my next step(s) should be? I am not much of an electrical or motor guy.
Thx, Lloyd
-- Northern California http://www.lloydus.com
View treeman's profile
treeman
149 posts in 348 days
106 days ago
I don’t know about the Delta but my saw has thermal overload protection. If it gets too hot it will kick off. There is a reset button on my saw motor you have to press to reset it. You might check and see if yours has one.
2462 posts in 240 days
106 days ago
i would check the switch ,
most of my tool problems are there .
the overload is a good bet too ,
as treeman sugjests .
had one tool that i had to really bang it
under flush .
try air in all the electrical places ,
sometimes sawdust gets into contacts .
View knotscott's profile
knotscott
532 posts in 274 days
106 days ago
IIRC, the 34-670 was one of the predecessors to the current TS300 which has a universal motor.(?) If you didn’t smell anything like burning electronics, it could be just a circuit breaker on the saw or in your electrical box. Let it cool and see if you can find a reset button.
Beginningwoodworker
4233 posts in 572 days
106 days ago
You might need to let the motor cool and hit the reset button.
-- CJIII Future cabinetmaker
View mmtool's profile
mmtool
22 posts in 466 days
106 days ago
I have worked on this Delta TableSaw quite a bit and it sounds to me like you may have burnt up the brushes. I would recommend you checking your brushes to see if they still have contact. If there isn’t contact then the good news is brushes are very inexpensive and easy to replace. If you do need to replace the brushes, you would need Delta brush part # 1313113 for the Delta 34-670.
Good luck!
-- Don, Utah, www.toolsandmachinery.com
View RedShirt013's profile
RedShirt013
118 posts in 560 days
106 days ago
My delta contractor went dead before and it was the switch that burnt out. Not sure of your model, but on mine the switch connect to motor via a power cable w/ male connector, I can bypass the switch and supply power to the motor directly using a computer power cable. If your saw is similar that’s a quick way to see if your switch is broken. Computer cable is thin gauge though so don’t run it for too long
-- Ed
View reggiek's profile
reggiek
716 posts in 169 days
106 days ago
How old is the saw? I wouldn’t suspect the brushes unless the saw is over a year or so old. It is also hard to smell the burning circuits through all the wood dust probably…but I would use a circuit tester…or a meter to see if the voltage is going through the switch….if it is…check at the motor where the inverter or voltage converter feeds the motor…..those are the two most suspect here….if they are intact and working then it is the motor….at that point you hope it is still under warrantee….
My .02 cents…
View blackcherry's profile
blackcherry
731 posts in 722 days
106 days ago
Try this first before you go replacing the brushes. Release the tension from the motor and vac the entire motor area. Replace the belt and hand rotate the belt. Next unplug the motor plug and reconnect. Then try and start the saw. I hope this is a quick fix…Blkcherry
View Brian024's profile
Brian024
57 posts in 299 days
106 days ago
Like Treeman said, you may have gotten the overloads to hot. They are made of solder coil and if the motor draws to much current, it causes the solder to melt and cause a switch to cut the saw off. There may be a reset button around the motor area or you can just let it cool down and try again.
