| Forum topic by MedicKen | posted 107 days ago | 439 views | 0 times favorited | 20 replies | ![]() |
107 days ago |
I am almost finished with an older Delta unisaw, 1968 model. It is undergoing a complete restoration and will become my workhorse. I am adding an extension table and have installed a Biesemeyer fence. I am looking for opinions on what others are using for mobile bases. I could fab my own but I have enough work piled up that I dont really want to take the time. Thoughts and experiences would be greatly appreciated. -- My job is to give my kids things to discuss with their therapist....medic20447@gmail.com |
107 days ago |
Ken, What’s the weight of the saw? Alot of mobile bases I’ve seen were not capable of handling the weight capacity they claimed. The last thing you need is that beast wobbling around while trying to cut something. I’ve had to reweld one and modify the other. Nothing beats a homemade welded base. John |
107 days ago |
Hey John…..I am guessing somewhere in the neighborhood of 400#. I know that a welded base would be the best but I dont have the time and access to a welder is almost non existent. I can weld, no welder. -- My job is to give my kids things to discuss with their therapist....medic20447@gmail.com |
106 days ago |
•Expands from 14” x 14” (36×36 cm) to 22” x 54” (56×137 cm) to accommodate table saws, drill presses, etc •Maximum dimension of 38 sq. ft •400 lb. (181 kg) capacity •Foot-lever action raises base for mobility, lowers base onto levelling feet for added support on uneven surfaces http://i300.photobucket.com/albums/nn11/GMman_2008/0556838_1.jpg•Heavy-duty 3” casters for easy manoeuvrability -- --<<<<<< I will not stop until I get it right. >>>>>>-- |
106 days ago |
Was $100 on sale for $40 -- --<<<<<< I will not stop until I get it right. >>>>>>-- |
106 days ago |
Hey Ken, Grizzly sells this, says it has a 700# capasity: http://www.grizzly.com/products/Heavy-Duty-Mobile-Base/G7314 And here’s an extention kit for it http://www.grizzly.com/products/Extension-Kit-For-Shop-Fox-Mobile-Bases/G8684 Hope this helps. -- "At its best, life is completely unpredictable." - Christopher Walken |
106 days ago |
Chris…you have exatly what Ken needs. -- --<<<<<< I will not stop until I get it right. >>>>>>-- |
106 days ago |
The Grizzly product looks good, I have a mobile base on my drum sander that has a lever sicking out the front that you step on to move the sander, the problem is that the lever sticks out too far and I am constantly triping over it or banging my ankle on it. Hate the thing but i guess not enough to change it out, avoid that kind of product. -- Paul, La Center, Washington |
106 days ago |
GMman…. the photo has been removed from the hosting site. I am interested in what you have posted but I can see a pic. If you could repost it would be appreciated. Chris….I had one of the Shop Fox bases under a jointer, same model in fact, and I didnt like it. The leveling feet are held inplace by magnets, and not very good ones either. When moved the feet would fall out and get caught in the joints in the concrete. I almost dumped the jointer more than once. Paul…I would be interested in seeing what you have. I like the idea of foot operated. In your case do you have the option of moving the actuator to the side of the machine that doesnt see as much traffic? On my unisaw I would be able to place the foot lever under the router table and not be a hazard but still able to use. -- My job is to give my kids things to discuss with their therapist....medic20447@gmail.com |
106 days ago |
Oh, sorry about the experience with the base. I just remember seeing them in the Grizzly catolog. I hope you find what you need. -- "At its best, life is completely unpredictable." - Christopher Walken |
106 days ago |
You might want to take a look at the HTC3000. It has a 700lb capacity and cost about 95.00 thru rockler. Nice sturdy base for the money. Cheers/Wudbutcher -- Big Steve |
106 days ago |
I would go with the HTC. I’ve had it under my Delta tilting arbor with extension table ever since I bought the saw 15 years ago. Constantly moving it around and the never had a problem. -- Always remember you're unique, just like everyone else |
106 days ago |
Ken, John |
106 days ago |
I have this (an older version) on mine: -- I'm a lumberjock and I'm ok, I sleep all night and I work all day! |
106 days ago |
•Expands from 14” x 14” (36×36 cm) to 22” x 54” (56×137 cm) to accommodate table saws, drill presses, etc •Maximum dimension of 38 sq. ft •400 lb. (181 kg) capacity •Foot-lever action raises base for mobility, lowers base onto levelling feet for added support on uneven surfaces •Heavy-duty 3” casters for easy manoeuvrability -- --<<<<<< I will not stop until I get it right. >>>>>>-- |
106 days ago |
Very good buy Date: July 20, 2009 “I bought mine at 65% off. My only regret is that I did not buy another one for my drill press. Highly recommended when on sale.” Click for larger images -- --<<<<<< I will not stop until I get it right. >>>>>>-- |
106 days ago |
http://i300.photobucket.com/albums/nn11/GMman_2008/0556838_1.jpg -- --<<<<<< I will not stop until I get it right. >>>>>>-- |
106 days ago |
http://i300.photobucket.com/albums/nn11/GMman_2008/photoThumb.jpg -- --<<<<<< I will not stop until I get it right. >>>>>>-- |
106 days ago |
I have the HTC, use it on my band saw. About half the weight of your saw, but either would be well within specs. I like it. |
106 days ago |
Don’t buy the grizzly (shop fox) base. I have it on my band saw and it is a POS. The frame is good but the casters suck. Even with the light weight of a 300# band saw it is still hard as hell to steer the thing around. Save up a few more bucks and by and HTC. IF you want the cats meow check to see if the SS industrial base will fit. Hydraulic rasing and lowering, but it is a $300 base. |
106 days ago |
I bought a “pump truck” for a “buck” at an auction,...........one $ dollar $ I put my cabinet saw/system on a skid, bolted it down, and use a manual skid steer ( aka manual pump truck ) and I dont think anyone can beat it…..............for a buck, it works like a MILLION bucks. I simply use the pump and pump up the skid the CS is bolted down on….......move the whole system to where it works…....release the pressure of the hydraulics….........and get to work |
| Forum | Topics |
Woodworking Skill Share
2928 |
3961 |
257 |
955 |
226 |
Woodworking Trade & Swap
622 |
Coffee Lounge
2398 |
LumberJocks.com Site Feedback
524 |
