bewildered by dovetail jigs
Forum topic by AaronK posted 105 days ago 668 views 0 times favorited 22 replies Add to Favorites Watch
View AaronK's profile
AaronK
409 posts in 361 days
105 days ago
Topic tags/keywords: question
I’m sort of set on going the router jig route when it comes to dovetails. I dont think i’ll have a pressing need to do variable spacing a la Leigh, but i would like to have half-blind and through capabilities.
Having never used one before, I’m wondering what the differences are between the various jigs in the 100-200 $ range. There are the rockler/mcls/PC type that have the cam clamping setup and all that, and then there’s the stots/keller type systems that are stand alone templates.
Some reviews on this site and elsewhere say that the rockler is good to ok, but others say that adjustments are finicky. Meanwhile everyone seems to rave about the keller. What i dont get is, how can a “built up” sort of jig like the rockler be in any way more difficult that a flat template like the keller? furthermore, are the mlcs/PC better than the rockler in that respect?
I’m just not aquainted with the intricacies of the various systems, so any help and clarification would help a bunch!
View ajosephg's profile
ajosephg
443 posts in 458 days
105 days ago
After much consideration and reviewing hundreds of posts on LJ’s I bought a PC4212 and later added a box joint template (which makes it a 4216) and have been well satisfied.
I’ve forgotten a lot of the details in my thought process but I seem to remember that several of the deciding points was that the PC templates are metal versus plastic and most of the LJ’s seemed to like the PC bettr than the Rockler.
-- Joe
View Geedubs's profile
Geedubs
44 posts in 126 days
105 days ago
Thanks for asking the questions AaronK. I hope to get a dovetail jig myself in the next few months and will be very interested in the thoughts of others on this subject. Love the Lumberjocks platform for information sharing!
-- "Setbacks are just opportunities to re-think your position." DAVID OVERBAY, father of Andy Overbay
View LesB's profile
LesB
551 posts in 340 days
105 days ago
Short of having a generous budget to a Leigh dovetail jig the Porter Cable is probably the best bet. If you expect to do lots of dovetails and other “fancier” joints look carefully at the features of the Leigh. I put it off for years until I could justify the expense and wish I had done it sooner.
-- Les B, Oregon
View rwyoung's profile
rwyoung
167 posts in 369 days
105 days ago
The PC4212 is a pretty good option. You can do “skip spacing” with this jig which moves you a little by away from the machine cut look. Of course it is still machine cut but makes a nice change of pace.
At one point there was a rebate on the PC4212 but that may have expired. You might look into that. Also, check around and see if you can find a local woodworking guild/club. There is a good chance somebody there has one you can try out.
-- Don't sweat the petty things and don't pet the sweaty things.
View TomHintz's profile
TomHintz
83 posts in 295 days
105 days ago
Aaron,
You will find someone who has had problems with virtually any dovetail jig, often stemming from the initial setup or poor instructions that came with the jig. I have been sold on the Leigh jigs for a long time because of their overall quality, solid engineering and the best user guides in this or virtually any other business. (Note that some say Liegh is “complicated” because their user guide is so thick. Really, it is very complete with large illustrations that you can actually see easily. That all makes it bigger.)
I have reviews of a few Leigh and other jigs at the link below if that kind of info would be helpful to you.
http://www.newwoodworker.com/reviews/index.html#routerjigs
-- Tom Hintz, www.newwoodworker.com
View CaptainSkully's profile
CaptainSkully
495 posts in 455 days
105 days ago
After doing a ton of research, I bought the Leigh Super 12” jig. I wanted to be able to make half-blind dovetails with a single pass, so they would have to fit together. This is standard on the drawers I’m trying to make. There are a lot of jigs, with plates. I bought a cheap one from one of the woodworking stores years ago and never got it to work (probably my fault).
I can tell you from the little experience I’ve had with my jig so far (I bought it right before “the accident”) that it works pretty well. I followed the thick booklet and watched the videos ad nauseum, but I made the scrap pieces, labeled them and followed the directions. Until my collet spun loose from the motor on my Hitachi M12V 3 1/3 HP router, I was making perfectly accurate, half-blind dovetails. It wasn’t until my father-in-law was helping me threadlock the collet back on that I took the pieces that I’d partially dovetailed and put them together. They fit perfectly.
Because my router weighs 11 pounds, I bought the accessory rest. It was a no-duh for me to avoid the tip & gouge method of dovetail jigging. I don’t care about dust collection or any of that other stuff. When I get done with my new mortising maching, I’m going to give the dovetail jig a run for it’s money. I know first hand that anything that’s powerful is not easy. Whether it’s AutoCAD, SketchUp or a dovetail jig, don’t expect miracles unless you’re willing to work for them.
Any jig that comes with a fixed template will only do one thing. It may do that very well, but in the words of Alton Brown, it’s a “uni-tasker”. It also may be considerably easier to comprehend and use, but who’s to say…
I made a box-joint jig from scrap red oak and the jigs that do the same thing are ridiculously expensive. People that say they want a metal jig have never dug a brand new router bit into pot metal. I’d rather gouge a piece of plastic. At least then I’ve only ruined the jig and not the bit…
If you just cut a bunch of tails and pins on two oversided pieces, you an always trim them down to fit perfectly and have the edges match. I’m amazed that no one ever says this. I know it’s a slight waste of material, but it’s a great way for beginners to make dovetail joints without all of the accuracy to do it all in one shot.
I’m actually going to remake the drawers on my gentleman’s chest (which currently have lock-joints) so that they have half-blind dovetails.
-- You can't control the wind, but you can trim your sails
View Mikeyf56's profile
Mikeyf56
103 posts in 118 days
105 days ago
Aaron, while it may be out of your budget, I think you may want to take a look at Akeda. The jig is truly plug and play, and no 100 page manuals to study or DVD’s to watch.
-- Powered by Smith & Wilson~~~
AaronK
104 days ago
thanks all for your comments. unfortunately jigs like the leigh and akeda are out of the question… a new table saw or bandsaw would be coming in way before then!
i’m still holding out for more opinions though… so far no one has had a thing to saw about mlcs or keller. and i still dont get how the keller could be easier than mlcs/rockler. And if so, would it then be better to get the mlcs template (stand alone) since it’s the same principle as the keller?
AaronK
104 days ago
also, Tom, thanks for a very informative site. I found your site about a year ago and have read many of the articles, they were/still are very helpful in getting me started in this hobby.
View gizmodyne's profile
gizmodyne
1678 posts in 987 days
104 days ago
I initially bought the porter cable 12” and then realized that you can’t make half blind dovetails in 1/2” stock. I returned it for the Leigh 16”.
rwyoung
104 days ago
gizmodyne -
Not sure I understand your issues with the Porter Cable jig. I’ve used 1/2” material in the PC4212 without serious difficulty making 1/2-blind joints. However I did have to make several test cuts to get it adjusted. It would probably have been better to use the 4215 accessory (which I don’t have) to work with the thinner stock as there just wasn’t much material left on the socket board with the larger dovetail bit. Ultimately I didn’t end up using the 1/2” material for a drawer front, seemed too thin. It was good practice for setting up the jig though.
AaronK -
One thing I’m not sure people realize you can do with the Porter Cable 42xx templates is that you can remove them from the jig and use them much the same way that the MLCS and Keller jigs work. It does require building some clamping boards and a little bit of jig making. The upside is you are no longer limited to a 12” wide workpiece.
7666 posts in 1115 days
104 days ago
Very satisfied PC4212 customer here.
John (gizmodyne), like AaronK said, there is no problem making 1/2 blind dovetails in 1/2” stock with this jig. I’ve done it many times.
View Richforever's profile
Richforever
340 posts in 617 days
104 days ago
Having used the Rockler, I’ve found the plastic offset pieces to be not so stable. Also, the setup can be pretty tricky; and screws that need to be adjusted are hard to get to. Seems like it was not so well designed as some of the other jigs. I’m now considering the Fast Joint system from MLCS.
-- Rich, Seattle, WA
View huff's profile
huff
1628 posts in 182 days
104 days ago
Aaron, I’ve been using the Porter Cable 7116 (24”) jig for years…..and years…...and years. lol. It’s been a great jig and I’ve never been sorry . I don’t know if PC still makes it, but I have the optional plate with the adjustable fingers. (great option). I’ve done 1/2” drawer boxes on mine, but changed bits and changed the depth of cut as specified. Set-up is critical, so I stay with 5/8” stock for all my drawers and designate one router strictly for dovetailing and never mess with the set-up. The saving of time in set up and adjustments is well worth the price of a seperate router. I use the PC 1 1/2 hp “D” handle router for dovetailing. I like the control I get with the handle. No matter what jig you get, it will take you a while to get comfortable with it and the set-up is really critical. Good luck and we look forward to those dovetail drawers in your future projects.
-- John @ Myrtle Beach
View Bryon McGowan's profile
Bryon McGowan
28 posts in 143 days
104 days ago
Some advice on a Porter-Cable 4212 12-Inch Deluxe Dovetail Jig PLEASE! copy and paste this title in the searsh box the pod cast is half way down the post is a great lesson on how to use the PC jig it is about an hour long. well worth the time I think that the orginal post was by brad
-- God is great beer is good and people are crazy
AaronK
103 days ago
first off, thanks to everyone for weighing in – but by all means lets keep this discussion going.
For me, it looks like the PC 4212 might be the best bet. it has versatility – can be used like the Keller or in its constructed jig. It uses aluminum, not plastic, templates to minimize deflection. it comes with an extensive user manual which i’m sure could be adapted to the other similar jigs, but is specific to the PC. it arrives with through, half blind, box, and other options. and, the price is right (i think i’ll wait for a sale/rebate).
gizmodyne
103 days ago
I guess the problem I had was that the side stock was slightly under 1/2” and I could not get the machine to work with it. Sorry for the confusion.
AaronK
98 days ago
i found this useful discussion on the bt3 forum. http://www.bt3central.com/archive/index.php?t-17090.html
seems like the PC 4212 made a lot of sense over there too.
View FlWoodRat's profile
FlWoodRat
584 posts in 806 days
98 days ago
Why not save the cash and cut them by hand?
-- I love the smell of sawdust in the morning....
View reggiek's profile
reggiek
717 posts in 167 days
98 days ago
I have the PC omnijig…It is an excellent jig…but I find that I enjoy cutting the joints by hand…it is infinitely more satisfying….I use the jig now for sliding dovetails and quick box joints. It is a bit overkill compared to the 4212….but I bought it used for about the same price…The adjustible feature was what intrigued me…It is a great jig all in all…but having worked with my grandfather doing joins by hand has made me lean towards the traditional.
There are numerous easy to make jigs for your router table…or for hand held cutting…that way you save the extra dough for more useful items…
my .02 cents…
View spanky's profile
spanky
12 posts in 305 days
98 days ago
The Incra LS Router Table Fence is the best buy for the money, in my opinion. You can do all types of dovetail and box joints, plus almost anything else you would use a router table for. I have two that I use everyday, and don’t know how I got along with out them. Just the repeatability when moving from one measuement to another is an amazing labor saver. There are some great demonstration vidios on thier web site.
View romanf's profile
romanf
6 posts in 153 days
84 days ago
I am not sure that after buying the 4212 and then adding all the templates you might need you may be getting close to the cost of an Akeda. The Akeda does not need templates or anything else to start making dovetails, finger joints, etc. You can also create variably spaced joints as well. I have found this jig to be extremely easy to use, which is half the battle in my opinion. Leigh and PC units look impressive but are not as simple to use as the Akeda is. Cheaper isn’t always better. If cheap is the need, get a Harbor Freight jig, which is the Woodstock unit. I have one of those and have made many fine half blind joints with it. Can’t beat it for $30, but if you need through cuts I still think the Akeda is the way to go.
