DELTA 1/2" Hollow Mortising Chisel & Chisel Bit
Forum topic by daddywoofdawg posted 05-08-2015 05:08 PM 1265 views 0 times favorited 6 replies Add to Favorites Watch
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1780 days
05-08-2015 05:08 PM
Topic tags/keywords: drill press
I’m looking at a used DELTA 1/2” Hollow Mortising Chisel & Chisel Bit;My question is can I chuck this into a standard drill press or do I need to use this only in a DELTA Hollow Mortising machine?Is there other parts that I need to make it work,I.E adapter,tool holder etc.I don’t know anything about them other than seen them and know what they do.
View Kazooman's profile (online now)
Kazooman
1241 posts in 2157 days
#1 posted 05-08-2015 05:14 PM
You need either a dedicated mortise machine or an adapter for your drill press. The adapter holds the square chisel in place while the drill bit spins inside. The drill bit takes out the bulk of the material and the chisel cleans up the corners.
Image from http://www.homedepot.com/catalog/productImages/1000/61/618aab18-cbdf-45dd-b748-836b1c511aa7_1000.jpg.
daddywoofdawg
#2 posted 05-08-2015 05:27 PM
ok so it maybe cheaper to just get a machine.glad I asked thank you.
runswithscissors
2897 posts in 2230 days
#3 posted 05-09-2015 05:10 AM
If you check out some of the threads on here about mortising adapters for drill presses, you’ll find that most people despise them. Not all, but most. A dedicated mortiser works much better, but even they have their frustrating aspects.
View conifur's profile
conifur
955 posts in 1357 days
#4 posted 05-09-2015 10:50 AM
In my experience, you will not get enough leverage on a drill press adapter, and will become very frustrated with it.
View Gentile's profile
Gentile
314 posts in 2023 days
#5 posted 05-09-2015 03:47 PM
I used to have one and it was a pain. It ties up the drill press when needed.
I picked up a Jet stand alone mortiser that I bolt to a counter when I need to use it. The Jet ain’t the best one out there, but I works well for my stuff.
-- "I cut it twice and it's still too short"
5177 posts in 2698 days
#6 posted 05-09-2015 04:08 PM
Regardless of whether it’s a DP attachment, or a dedicated mortiser, the Delta mortising bits aren’t the best anyway, dull quickly and don’t sharpen well (even with the sharpening aids). I replaced mine with Clico.
