Trying To Finish Over Linseed Oil
Forum topic by lobro4 posted 106 days ago 446 views 0 times favorited 9 replies Add to Favorites Watch
View lobro4's profile (online now)
lobro4
48 posts in 110 days
106 days ago
I constructed a bedframe and side table out of hard maple. Instead of stain applied and then wiped off 2 coats of boiled linseed oil. Took my furniture to a local shop that has done some finishing for me in the past. Now for the problem. The surface or the wood is still slightly gummy and can’t/won’t dry enough to allow the shop to apply a topcoat. Any clues on what can be used to wipe the surface or prep the surface to allow a top coat to stick? They tried to sand a little but it just gums up. Any clues out there? Any options other than oil based paint? Help!
-- Rock Chalk Jayhawk Go KU!!
View rwyoung's profile
rwyoung
167 posts in 369 days
105 days ago
It can take weeks for BLO to dry under certain conditions. It has been pretty humid around here lately so that may part of the problem.
How long ago did you apply the BLO? You may have to keep wiping it down, possibly give it a wipe down with some mineral spirits (do it outside).
-- Don't sweat the petty things and don't pet the sweaty things.
lobro4
105 days ago
Its been over 2 weeks. Seems like BLO has been dry in a few days for me in the past. I have thought about a mineral spirit scrub. I am wondering if something like naphtha or acetone might provide more kick. Anybody have any thoughts?
View SwedishIron's profile
SwedishIron
81 posts in 538 days
105 days ago
Did you wipe off the excess BLO several times after you applied it? I’ll wipe down a piece 3 or 4 times for 24 hours after I’ve applied it.
-- Scott, Colorado
lobro4
105 days ago
Yes… I wore out one elbow and the opposite wrist wiping off excess. Guess I should have cut the oil more with mineral spirits.
View CharlesNeil's profile
CharlesNeil
159 posts in 768 days
105 days ago
odds are the blo , isnt BLO, meaning not boiled….they simply add japan drier, and it just doesnt dry…I hate BLO, for this very reason, seems all the manufactures are cutting corners, yes a good scrub with acetone will probably do it , lacquer thinner is another option, in the worst case use MEK, ( methal ethel Keytone), it is expensive but will cut about anything…next time try some waterlox thinned about 20% with mineral spirits, or naptha, naptha dries faster, or some General finishes seal a cell….these work extremely well and dry quickly, not cheap…but you will get what you paid for…
View Chris Wright's profile
Chris Wright
360 posts in 379 days
105 days ago
You can try wiping off the excess with a rag wet with thinner or mineral spirits to take any excess off. If that doesn’t work, you can try a card scraper to remove the excess.
-- "At its best, life is completely unpredictable." - Christopher Walken
View notottoman's profile
notottoman
465 posts in 128 days
105 days ago
Defintly NOT BLO wax on …wax off…
-- "Even small steps makes a distance." (Shawn Phillips, musician)
17019 posts in 475 days
96 days ago
After wiping excess blo off with mineral spirits apply shellac and then whatever new finish you want the shellac acts as a sealer and will allow any other finish over the top.
-- Jim from Heirloom Woodshop Southern Oregon, custom furniture,woodworking school,heirloomwoodshop.com
View Julian's profile
Julian
695 posts in 423 days
96 days ago
Jim has the right idea. Make sure to use dewaxed shellac, especially if you are going to be using lacquer as a topcoat.
-- Julian, Park Forest, IL
