Drum Sander Snipe?
Forum topic by WhiskeyCreek posted 05-08-2015 05:05 AM 1172 views 0 times favorited 6 replies Add to Favorites Watch
View WhiskeyCreek's profile
WhiskeyCreek
17 posts in 1055 days
05-08-2015 05:05 AM
Topic tags/keywords: question
I have been getting used to my new drum sander and have had good results, but I keep getting rolled over edges at the front and back edge. I cut my wood oversize so I can cut and get really sharp edges before assembly, but I was curious if this was a normal experience for drum sanders. I don’t have infeed and outfeed extension but the bed is still pretty big. I am curious if I am doing something wrong or if this is a normal experience kind of like snipe on
-- Whiskey Creek Woodmill & Co.
View rwe2156's profile
rwe2156
2794 posts in 1382 days
#1 posted 05-08-2015 10:14 AM
What kind of machine?
View ellen35's profile
ellen35
2734 posts in 3334 days
#2 posted 05-08-2015 10:30 AM
Never had snipe on my 16-32 drum sander. I hold the wood down on the infeed side until it is near the head of the housing and then hold it down on the other side. You may need infeed/outfeed extensions. It’s not like a planer where you have rollers…
4868 posts in 2395 days
#3 posted 05-08-2015 11:14 AM
Knowing which sander you have would be helpful. The Delta models have pressure roller and can cause that. Another question: if the wood perfectly flat?
View Ghidrah's profile
Ghidrah
667 posts in 1124 days
#4 posted 05-08-2015 03:08 PM
I have the Performax 22-44 + with infeed and outfeed tables and while they help a lot with smaller shorter items they are ineffective for larger longer heavier items. Invest in a couple roller stands to extend support out from the feed tables. I use a straight edge to set mine a smidge high above the in/outfeed tables.
-- I meant to do that!
WhiskeyCreek
#5 posted 05-08-2015 04:48 PM
The sander is a Ryobi WDS1600 open ended 16 – 32 in. The pieces are for the most part flat but, I did have a question if you could use a drum sander in the same way you can stack plane on a planer. The planer does have rollers before and after the drum, are these pressure rollers or not?
View moke's profile
moke
1102 posts in 2678 days
#6 posted 05-08-2015 05:59 PM
I have the supermax and I do get a little snipe on long boards. I have been drum sanding maple lately instead of planing. I was getting some tear out by planing….I just hold up on the board for the first and last foot or so, and then I have no issue.
Mike
-- Mike
