first…pine dont like to bend, spruce will somewhat, and at 38mm , approx 1 1/2 it will probably be very tough, pine has alot of resin , which prevents it from getting wet enough to really soften the fiber, you would be much better lamanating the bend, you will have to get it really hot, the PVC is a great idea, one of the best steam sources I have come across is a good wallpaper steamer, they have a semi closed system , which is needed to get steam over the typical 212 degree mark, the average time is about 1 hour for each inch of thickness , pine I would go longer…..green wood bends better than dried wood , by far, but once steamed dries down very quick, as to time to keep it in clamps , several days ,on the pine, if it bends…be sure to overbend it to allow for spring back, perhaps an extra inch, ( 25mm) , this will be interesting to see how it bends….the biggest thing with the pine will be getting it as hot as possible to soften the resin, if it has been dried…pine is often heated to about 160 degrees to “set the resin”, best of luck to you…hope this helped
