Foot switch
Forum topic by AndreasVZ posted 05-07-2015 03:00 PM 834 views 0 times favorited 5 replies Add to Favorites Watch
View AndreasVZ's profile
AndreasVZ
2 posts in 1021 days
05-07-2015 03:00 PM
Topic tags/keywords: resource tip power strip switch
I tought to share this.
Wanting to have my hands free while working with the bench drill or another power tool, I tried using a sewing machine pedal but the power was just too much that it just burnt. So instead of having the voltage regulator in addition; just went to homedepot and saw these doorbell switches, that in addition with some power strip and outlets, made them into these foot switch:
5 replies so far
View MrUnix's profile
MrUnix
6330 posts in 2102 days
#1 posted 05-07-2015 04:13 PM
Love the creativity… but I have to ask; what is that switch rated at? Door bells typically work on 24v and that is what those switches are designed for, not 120v, and not for any kind of amperage that you might encounter on a power tool.
View Yonak's profile
Yonak
986 posts in 1424 days
#2 posted 05-07-2015 05:47 PM
Good idea, Andreas.
Door bells typically work on 24v…
- MrUnix
You could get a light switch with a rocker action, or push-button. With a bit of deft footwork, that could do the trick for you.
MrUnix
#3 posted 05-07-2015 05:49 PM
You could get a light switch with a rocker action. With a bit of deft footwork, that could do the trick for you.
Or just get a real foot switch at HF for about $10 :)
View DBordello's profile
DBordello
132 posts in 1129 days
#4 posted 05-07-2015 05:49 PM
They also offer closet door switches that are rated for pretty good current.
I am worried about the current those switches are rated for.
AndreasVZ
#5 posted 05-08-2015 03:08 PM
- MrUnix
Yes, that sounds right but here where I live I would have to also include the shipping and handle rates, time waiting, etc.. etc.. so I bought and build them the same night.
I know the current it’s quite a problem, I would’n use them to operate one of these:
.. but as I said, mainly for my bench drill that uses a momentary power on while drilling or something with low consumption.
I’ll work with an upgrade version that supports more current and are easier to reach as with these I have to step over them instead of just rising the tip of the foot.
Thank you all for the comments!
