The perfect storm: Festool Track Saw + WoodPeckers
Forum topic by CharlesA posted 05-07-2015 11:27 AM 3416 views 0 times favorited 13 replies Add to Favorites Watch
View CharlesA's profile
CharlesA
3342 posts in 1969 days
05-07-2015 11:27 AM
In case the price of a Festool Track Saw is not enough for you, you can now add a really expensive track guide system to the mix from Woodpeckers!
13 replies so far
View bigblockyeti's profile
bigblockyeti
5248 posts in 1892 days
#1 posted 05-07-2015 11:36 AM
That’s high without the extra $70 for a Tupperware container to hold it.
View timbertailor's profile
timbertailor
1594 posts in 1595 days
#2 posted 05-07-2015 12:04 PM
Maybe if I was doing a LOT of repetitive work\cuts the same size at a job site, I may be able to justify its purchase but I would never get enough use out of it personally.
I mean, how many cuts does it really take to whittle down a sheet of plywood to fit the table saw?
View jar944's profile
jar944
127 posts in 1609 days
#3 posted 05-07-2015 12:56 PM
View hotbyte's profile
hotbyte
991 posts in 3147 days
#4 posted 05-07-2015 01:21 PM
I thought a big advantage of the track saw is you just plop it down on a cut line and go. Seems like a shop-made panel gauge to mark a line would be all you need. Should be able to mark just ends and middle, not the whole length.
View AZWoody's profile
AZWoody
1410 posts in 1395 days
#5 posted 05-07-2015 02:41 PM
Even though I don’t have a track saw, I do see the benefit.
Yes, as people say, the advantage of the tracksaw is being able to plop it down and go, but this will allow you to make sure your cut is parallel to the opposite edge and also, can make it repeatable.
I wouldn’t consider it a high price, especially if I was one of the people who don’t have a table saw and only a track saw.
View jmartel's profile (online now)
jmartel
8190 posts in 2321 days
#6 posted 05-07-2015 02:55 PM
- hotbyte
You don’t mark the whole length. You set the parallel guides, plop it down and go. Easily repeatable unlike marking because there’s no marking needed. This system makes it so it’s just as accurate as a TS. I don’t know that I’d buy one, but I do see the value.
hotbyte
#7 posted 05-07-2015 03:07 PM
Perhaps I should have included a smilee in my comments since it was mostly tongue-in-cheek. I’ve seen/read several times that an advantage of the track saw is you don’t have to do the off-set measuring, etc. required of using a circ saw and straight edge. Then, we see multi-hundred dollar jigs come to the market because, evidently, just plopping the track on a marked cut line isn’t good enough. I just thought it very ironic…
jmartel
#8 posted 05-07-2015 03:15 PM
It just depends, really. The parallel guide is for batch operations. You don’t necessarily need it. If you’re only making one rip cut and not 10 at the same width, then it’s more of a hassle than marking it and cutting on the marks. Nothing ironic about it. Some cuts would work better with the parallel guide, others don’t. You can certainly not use the parallel guide, just mark plop and go on all cuts. But if you want Tablesaw accuracy, then the parallel guide gets you there.
View distrbd's profile
distrbd
2252 posts in 2618 days
#9 posted 05-07-2015 03:29 PM
Perhaps I should have included a smilee in my comments since it was mostly tongue-in-cheek. I ve seen/read several times that an advantage of the track saw is you don t have to do the off-set measuring, etc. required of using a circ saw and straight edge. Then, we see multi-hundred dollar jigs come to the market because, evidently, just plopping the track on a marked cut line isn t good enough. I just thought it very ironic…
- hotbyte
This Item Will Not Be Available After Monday May 25th, 2015… Estimated Delivery September, 2015
I finally managed to justify the purchase of a Festool track saw and now this? oh man , this is getting more and more complicated.
-- Ken from Ontario, Canada
timbertailor
#10 posted 05-07-2015 03:35 PM
- hotbyte
- distrbd
Congratulations on your new acquisition Ken! I really want one too. Whether I really need it or not is the real hold up! Did you get the 55 or the 75? Feedback or a review somewhere?
View BroncoBrian's profile
BroncoBrian
831 posts in 2130 days
#11 posted 05-07-2015 06:57 PM
That is awesome. Looks like a quick accurate measuring device.
-- I think they could take sesame seeds off the market and I wouldn't even care. I can't imagine five years from now saying, "Man, remember sesame seeds? What happened? All the buns are blank."
distrbd
#12 posted 05-07-2015 07:02 PM
- timbertailor
Brad,that’s not how it works with me,lol, First I justify the purchase in my head, if after a period of few months I still feel I have to have it then I buy it, for now I’m still justifying.
BroncoBrian
#13 posted 05-07-2015 07:20 PM
I am holding out for the Starrett version at $800.
