Math for size of table
Forum topic by basuraman posted 05-06-2015 08:03 PM 689 views 0 times favorited 5 replies Add to Favorites Watch
View basuraman's profile
basuraman
25 posts in 3062 days
05-06-2015 08:03 PM
Topic tags/keywords: question
What math do you use to determine how big to make a table.
Do you use a certain size for each chiar and mulitply?
What ratio do you use for length vs width?
Are these silly questions?
5 replies so far
View Daruc's profile
Daruc
460 posts in 1133 days
#1 posted 05-06-2015 08:17 PM
I use basic math. No need for geometry or trig for that.
I figure 2’ per person. Depends where it is going for how wide I want it.
One of the first things to consider is how many people do you want to be able to seat?
A quick trip to your local department store that sells tables is also another alternative that way you can measure and feel the different sizes.
View hotbyte's profile
hotbyte
991 posts in 2976 days
#2 posted 05-06-2015 08:18 PM
Take a tape measure to your favorite restaurant and measure away while waiting on your food :)
View pintodeluxe's profile
pintodeluxe
5664 posts in 2814 days
#3 posted 05-06-2015 08:23 PM
24” per chair is a good place to start, but I also look at table leg placement. This often means table legs are 48” or more apart. On extension tables, I’m okay if a guest has to straddle a table leg when the table is expanded. However, I don’t want daily users to have to straddle a leg.
If the table has solid leg assemblies (think mission tables with spindles), then an additional 12-18” overhang should be considered for seating on either end.
basuraman
#4 posted 05-06-2015 09:01 PM
24” per chair is a good place to start, but I also look at table leg placement. This often means table legs are 48” or more apart. On extension tables, I m okay if a guest has to straddle a table leg when the table is expanded. However, I don t want daily users to have to straddle a leg.
- pintodeluxe
Thank you. I am looking to build a new outdoor farm style table for 10 so it is looking like a 10 foot table.
View MNclone's profile
MNclone
192 posts in 1585 days
#5 posted 05-06-2015 11:16 PM
- pintodeluxe
- basuraman
If you have seating on the ends, 8’ will suffice.
