craftsman bandsaw 137.224120, broken wheel shaft. replacement part?
Forum topic by joshtank posted 05-06-2015 07:23 PM 986 views 0 times favorited 1 reply Add to Favorites Watch
View joshtank's profile
224 posts in 2905 days
05-06-2015 07:23 PM
bleeergh shaft on the lower wheel broke today. i’ve got tons of use out of it, a lot of resawing. but i think the blade tension was up too high.
anyways i need one of these (and probably the key as well)
of course craftsman is out of them.
local machine shop can make one, but it’s $72 an hour. saw was $250 used.
also, not even sure how to get out old broken shaft.
anyone have this part laying around?
-- Josh - Jacksonville, FL -
1 reply so far
View mtenterprises's profile
933 posts in 2625 days
#1 posted 05-07-2015 12:16 PM
First to get the part out, there should be a set screw holding it in, remove it then set the wheel over a hole and tap it out with a hammer and punch. If there is no set screw you will need a press to press the broken end out.
Now as for the rest. Find locally a Jed In The Shed machinist, a guy like most of us woodworkers who does machine work as a hobby or a small business and see if he will trade machine work for wood work. It’s an easy job to make a shaft like that with a key way. OR another thought see if you have a machinist class at your local college or BOCES and make a donation to their party fund for making you the part.
-- See pictures on Flickr - And visit my Facebook page -
