| Forum topic by kem75 | posted 103 days ago | 444 views | 0 times favorited | 10 replies | ![]() |
103 days ago |
Topic tags/keywords: alder maple question I am not a woodworker so I need some advice. |
103 days ago |
Maple is harder then Alder but is a PIA to stain. It doesn’t absorb the stain as well, and will take a lot of coats to get it dark. You may even need to glaze it or tone it to the desired color. -- ~ Inspiring those who inspire me ~ |
103 days ago |
The only way Maple can be colored effectively and without blotching is with dyes. Dyes are not as light fast as stain and over time, any of them will fade as opposed to stain. Plus, when you use a dye, you are limited in your choice of top coat. Toners and glaze may get you a darker color but Maple doesn’t have a distinct grain and can start to muddy under a lot of layers. If you are married to a dark color, forego the maple. If you can stand Maple in it’s characteristic pale-creamy color (beautiful in it’s own setting), don’t stain it and just topcoat it with a water-base top coat. Think basketball court. -- Rock Chalk Jayhawk Go KU!! |
103 days ago |
I have natural colored solid hard maple cupboards and I’ll never regret it. Anything goes with it, we got all black appliances and a black corian counter, but the whole thing just melded when we added terra cotta tile floors. It just made it beautiful, if I were you thats the way I’d go. Like lobro said some clear topcoat is all you need. With black door knobs. Just a thought. -- Mike. mwurm13@yahoo.com |
103 days ago |
I believe a glaze is your best bet if you want a dark chocolate color. I made a table from maple for my daughter. She also wanted a dark stain. I sprayed a coat of ML Campbell lacquer followed by ML Campbell’s stain( I believe it is called miracle stain, but am unsure). The stain comes in many different colors. When spraying, you spray until you get the color you want. The stain dries quickly and I followed that up with another coat of lacquer. By using a glaze you shouldn’t have to worry about blotching. The down side is the wood itself is not colored. Hope this helps. pkennedy -- P Kennedy Crossville, TN |
103 days ago |
Are you talking about hard or soft maple. There is a big diiference in how they both take stain. It’s hard to get a dark stain on hard maple without some kind of glaze or shading. Then you run the risk of chipping the color, as the color is on top of the wood, or the finish, or both. Soft maple is typically blotchy. If you painter is not willing to do more than a quick coat of stain, you may have problems. Alder does tend to stain more evenly, and absorbs stain better than hard maple. Good luck -- Kent Shepherd * The goal is-----More Tools! |
97 days ago |
Just wanted to thank everyone for their helpful responses…we ended up going with maple due to discovering it would be an extra $1000 for alder…homebuilding is expensive! |
97 days ago |
the 1,000 bucks would have made up my mind too. LOL. I look forward to seeing the finished project -- ~ Inspiring those who inspire me ~ |
97 days ago |
I like and use the BAC wiping stains from Sherwin. They take a bit different than the DIY stains like Minwax, Bher, and the like. This is something that I try to explain to woodworkers because pro level products behave a bit differently. I do not experience the same level of trouble with stain and finish that woodworkers do and anybody can buy the same products that I do. Sherwin Williams stores are more prevalent than Woodcraft. I am also a big fan of the ML Campbell line. -- Todd A. Clippinger, Montana, http://amcraftsman.com |
97 days ago |
I posted on my website western red alder stained in a number of finnishes. These are sample board that I finished and then set on the scanner. Good Luck with the maple.. http://offthegridlights.com/index.php?option=com_expose&Itemid=28 -- Life is to short to own an ugly boat. |
97 days ago |
>We are getting custom cabinets and the painter only uses one coat of stain and one coat of sealer I’d look for a different painter. There’s no way one layer of topcoat is adequate for cabinets. It won’t properly seal the end grain on the stiles, just for an example. Just my .02 |
| Forum | Topics |
Woodworking Skill Share
2900 |
3920 |
256 |
943 |
222 |
Woodworking Trade & Swap
616 |
Coffee Lounge
2371 |
LumberJocks.com Site Feedback
522 |
