Need help with temporary nails
« back to Joinery forum
Forum topic by Andrew posted 05-06-2015 02:08 PM 783 views 0 times favorited 9 replies Add to Favorites Watch
View Andrew's profile
Andrew
39 posts in 2358 days
05-06-2015 02:08 PM
Topic tags/keywords: question walnut joining
I made a sliding wine box for My wedding in June, very similar to this one
I’ll post pics of mine shortly.
My question is how to nail it shut during the ceremony so I can still open it in 5 years without wrecking it. I am seeing tapered dowels or pins, but don’t think I have the capability for that. Never made anything like that. I don’t know any other way and hoping the years of experience here could help me out.
Any alternatives or ways to make the tapered dowels and holes would be much appreciated.
Andrew
-- If you don't start building your dreams, someone else will hire you to build theirs.
9 replies so far
View mahdee's profile
mahdee
3883 posts in 1763 days
#1 posted 05-06-2015 02:16 PM
You can use dowels instead. Cut two grooves on each side of them like a nail so they can be removed. May have to make a wooden tool with two prongs (like a tapered wrench) to remove the dowels.
-- earthartandfoods.com
Andrew
#2 posted 05-06-2015 02:21 PM
Are you saying cut/sand the whole dowel into a nail shape with a big head? I like that idea.
View rwe2156's profile
rwe2156
2923 posts in 1476 days
#3 posted 05-06-2015 02:31 PM
What about some decorative iron nails cut square nails put into snuggly drilled holes?
mahdee
#4 posted 05-06-2015 02:38 PM
Doesn’t have to look like a nail persay. Just the concept. The dowel can have a “ring” around it (it can be cut on a table saw/band saw or router). So long as you can utilize a tool to pull it out. Or you can get a couple of
or these
and modify them.
mahdee
#5 posted 05-06-2015 02:40 PM
Not sure if the images came through here is a link:
View SirIrb's profile
SirIrb
1239 posts in 1226 days
#6 posted 05-06-2015 02:44 PM
A duplex nail?
Ok, that was a joke.
EDIT:
Tap the hole and use a dowel that has been threaded. Then make the dowel have an octagonal head it is glued into. BOOM!—a wooden bolt to hold your wine door shut.
View hotbyte's profile
hotbyte
991 posts in 2971 days
#7 posted 05-06-2015 03:04 PM
Never seen anything like that…is it a new “tradition” for weddings?
How about some type of decorative screw/bolt? No idea if such a thing exists…just a thought on having something removable.
View BJODay's profile
BJODay
526 posts in 1938 days
#8 posted 05-06-2015 11:20 PM
I always called this a scaffolding nail. It is a double headed nail. It is used on construction sites for pieces that must be disassembled. They are not pretty.
BJ
View cutmantom's profile
cutmantom
405 posts in 3030 days
#9 posted 05-06-2015 11:40 PM
Use a s screw
