Homemade Drum Sander Questions
Forum topic by BigJon posted 05-06-2015 11:10 AM 1049 views 0 times favorited 7 replies Add to Favorites Watch
View BigJon's profile
BigJon
52 posts in 1913 days
05-06-2015 11:10 AM
Been lurking around for several months researching and reading everything I can find on homemade drum sanders. Still undecided on what I need. V drum vs the typical drum sander where the object to be sanded is pushed under the drum. Im both a machinist and steel fabricator by trade so construction is no problem but $cash$ is, so I only want to build it once. Mostly I will be sanding endgrain cutting boards and various other typical sanding tasks. It will have a 30” wide capacity with disk sander and ran by a 3 horse motor with a 5-6” diameter drum. Any thoughts on what type would be better for my use? Thanks In advance!
-- Im bleeding, go get my super glue and roll of black tape....
7 replies so far
View ohtimberwolf's profile
ohtimberwolf
749 posts in 2256 days
#1 posted 05-07-2015 12:16 AM
BigJon… a 5ft 6” drum? Wow, what a sander. When you get it made please post pictures. larry
-- Just a barn cat, now gone to cat heaven.
View bigblockyeti's profile
bigblockyeti
4981 posts in 1624 days
#2 posted 05-07-2015 01:07 AM
You will have a more precise machine if you opt to make a machine where you push the piece under the drum. Kind of like comparing the cutting principles of a jointer (more like a V-drum) vs. a traditional drum sander (more like a planer). Just depends on if you’re sanding and need to keep the work extremely flat with multiple passes or just a single pass or two to clean up the surface.
BigJon
#3 posted 05-07-2015 03:07 AM
Thanks for the input bigblockyeti !
View Rick_M's profile
Rick_M
11101 posts in 2284 days
#4 posted 05-07-2015 03:41 AM
I have seen several dual purpose machines with v-drum top and regular drum on bottom.
-- http://thewoodknack.blogspot.com/
View TheFridge's profile
TheFridge
8862 posts in 1390 days
#5 posted 05-07-2015 03:50 AM
Check out woodgears.ca . There could be a lot of useful info on there for building your own machine.
runswithscissors
2652 posts in 1929 days
#6 posted 05-08-2015 04:00 AM
The OP said a 5” to 6” DIAMETER drum, not 5’6” long.
ohtimberwolf
#7 posted 05-08-2015 12:10 PM
Wow, my stupid mistake…I should have looked more careful. My old eyes are not what they used to be. :)
