Saw for cutting logs lengthwise?
« back to Hand Tools forum
Forum topic by BreathMint76 posted 05-05-2015 09:07 PM 8727 views 1 time favorited 49 replies Add to Favorites Watch
View BreathMint76's profile
BreathMint76
1 post in 1114 days
05-05-2015 09:07 PM
Topic tags/keywords: saw question rip
I am planning to do a project that would require me to cut a log (About 6 in. in diameter and 3 feet long), but for several varying reasons I would rather not purchase a piece of machinery to do this. I was wondering what the best hand saw would be to do this with.
49 replies so far
18163 posts in 1853 days
#1 posted 05-05-2015 09:50 PM
A chain saw.
View DocBailey's profile
DocBailey
584 posts in 2357 days
#2 posted 05-05-2015 10:05 PM
^not helpful and not even funny
Your title seems to indicate that you want to rip the log—you’ll need either a coarse-toothed 4 – 5½ PPI rip handsaw or better still, a docking saw
OR
a frame saw.
The frame saw will, of course, need sufficent clearance between blade and brace bar so as to allow the log to pass through it as the cut progresses.
#3 posted 05-05-2015 11:05 PM
Wasnt trying to be funny. Many people have chainsaws. If he just needs to get the log in half and has one it will certainly do the job.
View trz's profile
trz
90 posts in 2483 days
#4 posted 05-06-2015 01:27 AM
Chainsaw would be my first choice
View upchuck's profile
upchuck
540 posts in 1662 days
#5 posted 05-06-2015 02:12 AM
My choice of tools would be what I have on hand: Sledge Hammer or Maul with wedges. If the wood was not too stringy and if it had even grain that was not interlocking it is possible to get a clean split. There would be more cleanup of the split surfaces then a sawn face but those are the tools I have on hand. With some woods this idea wouldn’t work.
TheWoodenOyster
1317 posts in 1932 days
#6 posted 05-06-2015 03:25 AM
Here is a frame saw specifically made for resawing. This type of frame is made to saw thru and basically have infinite clearance depthwise. You just couldn’t go with a massive diameter log.
-- The Wood Is Your Oyster
View OldEd's profile
OldEd
39 posts in 1609 days
#7 posted 05-06-2015 04:32 AM
I’d go with the chain saw… JUST AS LONG as you have a ripping chain on it. The normal chainsaw chain is a CROSS-CUT chain, after all. That’s what you are doing with it, isn’t it? Cross-cutting the trunk of the tree to fell it, or cut the limbs off, or sectioning it for whatever purpose, ranging from firewood or what ever…
I just googled “Chainsaw ripping chain” and got pointers to Oregon, which makes a “95R” ripping chain, which is just the thing for you, especially if you want to make planks out of the log…
Of course, you fell the tree with a cross-cut chain, and then switch.
-- OldEd
View Ghidrah's profile
Ghidrah
667 posts in 1219 days
#8 posted 05-06-2015 03:31 PM
Chain saw would chew up a lot of useable product, I’m a sissy when it comes to the amount of labor involved with doing it by hand. I’d begin looking for someone close by that had a BS and some Pam.
-- I meant to do that!
View JohnChung's profile
JohnChung
408 posts in 2071 days
#9 posted 05-06-2015 04:31 PM
I would suggest a wedge and hammer. It can split the wood in the middle.
View Wildwood's profile
Wildwood
2305 posts in 2131 days
#10 posted 05-06-2015 07:45 PM
Some species of wood with straight grain split lot easier than others. Knots concealed make splitting a log evenly more difficult by hand. When splitting logs over two feet long axes, mails, and wedges just too much work.
A homemade saw buck and one or two man rip cut saw would do the job.
Rip saw –a saw with rip teeth meant for cutting a board along its length (with the grain).
Crosscut saw a handsaw used to cut a board through its width (across the grain).
https://www.youtube.com/watch?v=l7zzqWMUq6I
Cost of a new or used rip saw today verus an electric chain saw?
I would be using homemade saw buck and electric chain saw faster and safe too!
-- Bill
runswithscissors
2751 posts in 2022 days
#11 posted 05-07-2015 07:34 AM
If it’s just a single cut, I wouldn’t bother with a ripping chain. They don’t rip that much better than a cross cutting chain, which will do just fine. But experiment with different angles of the saw to the log until you find the most efficient orientation.
View jar944's profile
jar944
127 posts in 1434 days
#12 posted 05-07-2015 12:50 PM
chainsaw.
noodle it (cut with the grain or as close to with the grain as possible) a std chain will be fine.
Edit didn’t realize this was in the hand tool forum.
View mahdee's profile
mahdee
3883 posts in 1764 days
#13 posted 05-07-2015 02:45 PM
If you have a fro, that might do the job the easiest way and least time consuming provided the piece is straight grain. Wedges work well too. A drawknife can clean the split followed by hand plane.
-- earthartandfoods.com
View SirIrb's profile
SirIrb
1239 posts in 1227 days
#14 posted 05-07-2015 02:56 PM
Chain saw
Chalk line
Bourbon
Ok, Bourbon for when you conquer it.
But you have to trash-talk the log first.
“Im about to rip you to shreds. You hear me, log? The rest of the forest will cry in fear when I get done with you. [swig of bourbon] You just got yourself too deep. Fear me, log, Im about to go loco on you.”
View ChuckV's profile
ChuckV
3118 posts in 3524 days
#15 posted 05-07-2015 03:21 PM
Do you have a really good friend to help?
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
showing 1 through 15 of 49 replies
