Miter saw stand extension?
Forum topic by AAANDRRREW posted 05-05-2015 05:11 PM 801 views 0 times favorited 1 reply Add to Favorites Watch
View AAANDRRREW's profile
AAANDRRREW
210 posts in 1138 days
05-05-2015 05:11 PM
So I have this stand, and love it:
http://www.amazon.com/Folding-Miter-Stand-PM-4000-Portamate/dp/B002HORLUO/ref=sr_1_1?ie=UTF8&qid=1430845364&sr=8-1&keywords=miter+saw+stand
Problem I am having is because it’s on a stand, I cannot use stop blocks easily. My buddy has his saw on a bench with some homemade fence (not sure if its called that on a miter saw) extensions that the wood can lay on and butt up to. He then can clamp his stop block to it. I cannot do this unless my piece I’m cutting is under 18” or so.
I was thinking of building a little fence extension and having a vertical piece of wood or steel that would slide into the slot that the miter saw stand extensions fit into. Then I could take them out when I store the stand.
Does what I propose make sense?
1 reply so far
woodbutcherbynight
4340 posts in 2375 days
#1 posted 05-06-2015 02:34 AM
I have a bench mounted miter saw as your friend does. When I want an extra 23” I have an extension that uses a simple mechanical catch to hold it to the fence keeping it lined up. But it has no back, only a flat bottom. You could use a similiar method but with a back on the extension. Below are 3 pics, hope this provides some inspiration.
