Options for 2-door cabinet with no center stile
Forum topic by BinghamtonEd posted 05-05-2015 03:54 PM 3993 views 0 times favorited 27 replies Add to Favorites Watch
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2365 days
05-05-2015 03:54 PM
I’m working on designing the new cabinets for my kitchen. The existing ones are at the end of their life, literally peeling, broken slides, etc, and for the most part, I’m doing a one-to-one replacement. Also convinced the wife to let me buy an Earlex and a PC dovetail jig.
We do have a 27” wide cabinet, and I’ll be adding two new sections at 30” each, that I will be building. I would like to build these without a center stile, but with two doors. The cabinets will have face frame, probably 1.5”. My question is, what are my options for the space between the two doors on a single cabinet, with no stile? I know I could leave a gap (but I don’t want to), or I could attach a strip to one of the doors, and that door would have to be closed first (kind of annoying, but not as annoying as the center stile or the gap).
Are there any other solutions out there that I don’t know of? At this point, I think I would add the strip to one door, and probably put a thin strip of foam or something on the back, so it would not damage the other door if the one with the strip was not closed first.
I think the only cabinet that will have two doors with an actual center stile is the 36” wide sink base, for structural support.
27 replies so far
4984 posts in 2489 days
#1 posted 05-05-2015 04:00 PM
I went with the gap, much handier and if it’s the same width (1/16”) as the one at perimeter of the doors, it’s not distracting. You may have to bevel the edge of the doors where they meet so they clear when being opened/closed but I still like that better than an astragal (is that what it’s called?) or a stile. BTW, you can do that on the sink base as well, just make the front rail thicker (or double it up, on the inside). It’s really handy where you have to get in for plumbing stuff.
BinghamtonEd
#2 posted 05-05-2015 04:08 PM
Thanks for the input, Fred. I should have mentioned that I am planning on 1/2” overlay doors, so there will be no gap on the perimeter of the doors.
#3 posted 05-05-2015 07:27 PM
Oops, I can see why you don’t want the gap. That centerpiece (astragal?) may be your only option. My doors were inset. It’s still a good idea, those center stiles are a PITA.
View Woodmaster1's profile
Woodmaster1
957 posts in 2583 days
#4 posted 05-05-2015 07:42 PM
I am in the process of making my cabinets with a center gap as tight possible. Aim using a half inch overlay and bevel edges. I will post pics when I get them done.
View waho6o9's profile
waho6o9
8189 posts in 2573 days
#5 posted 05-05-2015 09:23 PM
Could your doors be inset inside of the face frame and use
European hinges?
View Bill White's profile
Bill White
4929 posts in 3956 days
#6 posted 05-05-2015 09:56 PM
Small center gap is very common, and is of no concern for most. I hate the center stile too.
Bill
-- bill@magraphics.us
View felkadelic's profile
felkadelic
218 posts in 2536 days
#7 posted 05-05-2015 10:07 PM
I just checked the cabinet I have under my kitchen sink that’s setup like this (no center stile, overlay doors). There’s a small gap (maybe 3/32”) between the doors. I’ve never even thought about doing this another way, so obviously it doesn’t stand out as improper.
View hotbyte's profile
hotbyte
991 posts in 2971 days
#8 posted 05-06-2015 12:52 AM
You could get fancy and replicate the mechanism on French door fridges where either door can be opened or closed first. No idea how to implement on a cabinet.
View Kelly's profile
Kelly
2025 posts in 2940 days
#9 posted 05-06-2015 01:24 AM
I’ve played with rare earth magnets a lot, including using them to make removable panels (e.g., wainscoting) to hide things. From that, I’ve wondered why I couldn’t use them to solve this problem.
It would be a simple task to flush mount three magnets in each door and the center strip (nine magnets total). If positioning blocks were installed at the top and bottom of the doors, where they meet, pulling on only one door would leave the strip tied to the other door, and it closed. That would, of course, apply to either door.
You would not want to use heavy pull magnets. On a wild guess, only a couple pounds each, at most.
The other option would be, as noted by hotbyte, to do it like they do the double door fridges of the last decade. Pulling one door forces a peg to follow a path, flipping the “center board” to flip ninety degrees so the door can open and close.
BinghamtonEd
#10 posted 05-06-2015 12:38 PM
Woodmaster, definitely post pictures when you’re done, I’d like to see it.
I do not want to do inset doors. I could possibly redesign to cut the reveal around the doors/drawers down to 3/4” or so and minimize the size of the astragal I need to use is, so I don’t have such a large gap to fill.
View skipj's profile
skipj
97 posts in 2268 days
#11 posted 05-06-2015 01:57 PM
I do a lot of kitchens for my son in law,he is a contractor. If I would put a center stile in a sink
base he would shoot me and then grab a saw and cut it out.
BinghamtonEd
#12 posted 05-06-2015 02:06 PM
Skip, how do you handle that gap when you have overlay doors with a reveal?
skipj
#13 posted 05-06-2015 02:16 PM
I use blum adjustable hinges and get the gap as close as I can. All my doors are overlay.
Kelly
#14 posted 05-06-2015 04:03 PM
I installed a center style under my undermount sink, but used pocket screws, so it can be easily removed when the time to swap the sink arrives.
- skipj
BinghamtonEd
#15 posted 05-06-2015 04:34 PM
I think for the sink, I’m going to use an extra wide upper rail, doubled up, and attach a false drawer front. That should be sturdy enough. We keep cleaning supplies, sponges, etc down there, and we can never get to the stuff in the back, so I will probably put a full size (well, approx. 30” wide) pull-out in there with 100# full-extension slides.
