Portable band saw ... why?
Forum topic by CB_Cohick posted 05-05-2015 02:58 PM 1290 views 0 times favorited 15 replies Add to Favorites Watch
View CB_Cohick's profile
CB_Cohick
483 posts in 1124 days
05-05-2015 02:58 PM
Topic tags/keywords: question bandsaw portable
Every tool has a job for which it is the best solution. I see portable band saws on Craig’s List from time to time, and I always wonder, “What job is that the best tool for?” What say you, LJ’s?
-- Chris - Would work, but I'm too busy reading about woodwork.
15 replies so far
View jmartel's profile
jmartel
7632 posts in 2023 days
#1 posted 05-05-2015 03:13 PM
Those are used for cutting metal. Angle iron, flat bar, square stock type stuff.
View mramseyISU's profile
mramseyISU
529 posts in 1418 days
#2 posted 05-05-2015 03:14 PM
For cutting conduit and uni-strut would be my vote for them.
-- Trust me I'm an engineer.
4827 posts in 2366 days
#3 posted 05-05-2015 03:20 PM
If you work with metal, they are incredibly useful.
View crank49's profile
crank49
4028 posts in 2843 days
#4 posted 05-05-2015 03:30 PM
To a metal fabricator they are a “powered hacksaw”.
Sometimes a reciprocal saw, often referred to as a SawzAll, will work, or a grinder with a zip wheel might substitute, but the cleanest, smoothest working tool would be the “Porta Band”.
View SirIrb's profile
SirIrb
1239 posts in 1103 days
#5 posted 05-05-2015 03:43 PM
got an old 3” cast drain pipe. Zip, gone.
View TheFridge's profile
TheFridge
8659 posts in 1359 days
#6 posted 05-05-2015 03:53 PM
I have one I use all the time with metal.
View bonesbr549's profile
bonesbr549
1469 posts in 2940 days
#7 posted 05-05-2015 04:34 PM
Good for cutting down doors. Back in the college days, doing rehab in old houses, you had to custom cut a lot of doors and they were great for that. Pipes were easy with them as well.
View Jim Finn's profile
Jim Finn
2595 posts in 2795 days
#8 posted 05-05-2015 08:51 PM
before I retired from sheet metal work I used them often to cut unistrut and allthread rod.
View exelectrician's profile
exelectrician
2327 posts in 2300 days
#9 posted 05-05-2015 09:19 PM
Why ??? try cutting 30 2” conduits off exactly on the same length and dead square with a hack saw – You will soon know why!
-- Love thy neighbour as thyself
View Kelly's profile
Kelly
1874 posts in 2817 days
#10 posted 05-06-2015 01:36 AM
When I worked for REI, we renovated an apple storage shed and converted it into a sewing factory. Each floor had hundreds of feet of metal pipe that had carried ammonia for cooling the shed. Using one of these made quick work of cutting it all in to manageable pieces.
A Sawsall, or equivalent, could have done it, but not as smoothly and I would have gone through a number of blades. As it was, I only had to swap blades once.
View hotbyte's profile
hotbyte
989 posts in 2848 days
#11 posted 05-06-2015 01:39 AM
Not sure, but I’ve read they are used a lot in metal work :) :) :)
View Sylvain's profile
Sylvain
684 posts in 2372 days
#12 posted 05-06-2015 02:53 PM
there are carpenter portable bandsaw:
http://www.timbertools.com/Products/HEMA-portable-bandsaw-wood.html
-- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn
crank49
#13 posted 05-07-2015 08:40 AM
Those would be for timber framers.
With plenty of money.
But very interesting tools on that link, thanks for posting it.
- Sylvain
View robscastle's profile
robscastle
4713 posts in 2077 days
#14 posted 05-07-2015 09:34 AM
I have a portable bandsaw and its possiby one of the most borrowed tools I have.
So when my mates come around to borrow it I usually get them to help me fit a new blade as appreciation for the loan !!
Hull Oaks Sawmill.
Hey did you check out the:-
Scheer Router System for Profiling Stair Railings
Model FG 308
Now there is one impressive wood working tool !!
-- Regards Robert
SirIrb
#15 posted 05-07-2015 06:29 PM
I.
AM.
AMAZED.
PERIOD.
Hull Oaks Sawmill.
Model FG 308
- robscastle
