Can someone tell me what type of wood/ this dresser is I am refurbishing it for my mom.1st timer!
Forum topic by LittleGinas posted 05-05-2015 02:26 PM 1306 views 0 times favorited 13 replies Add to Favorites Watch
View LittleGinas's profile
LittleGinas
4 posts in 1024 days
05-05-2015 02:26 PM
Topic tags/keywords: question cherry walnut ash tip refurbishing
-- Thank you for being you! Gina.
13 replies so far
View mahdee's profile
mahdee
3844 posts in 1673 days
#1 posted 05-05-2015 03:20 PM
looks like pine of sort.
-- earthartandfoods.com
View albachippie's profile
albachippie
772 posts in 2941 days
#2 posted 05-05-2015 03:24 PM
Laminated pine board with an antique pine stain I’d say.
Welcome along Gina,
Garry
-- Garry fae Bonnie Scotland
View BurlyBob's profile
BurlyBob
5247 posts in 2171 days
#3 posted 05-05-2015 04:47 PM
Be careful ! There might be a lot of thin veneers on anything that is plywood. You can sand right thru those paper thin top veneers.
LittleGinas
#4 posted 05-05-2015 05:49 PM
Shoot I haven’t had it picked up it was $50 at flea market maybe I should keep looking
View Yonak's profile
Yonak
986 posts in 1427 days
#5 posted 05-05-2015 06:09 PM
It’s nothin’ fancy.
View JoeinGa's profile
JoeinGa
7733 posts in 1913 days
#6 posted 05-05-2015 06:40 PM
It might very well be pressed wood with a vinyl covering.
Oh yeah, WELCOME to LJs
Smitty_Cabinetshop
15111 posts in 2524 days
#7 posted 05-05-2015 06:44 PM
- JoeinGa
And those ‘wear marks’ around the door pulls sure reinforce that thought for me!
LittleGinas
#8 posted 05-05-2015 07:55 PM
Thank you all so much!! Going to keep looking. It is my first refurbishing and on a budget but I want to make it special for my mom. Sorry if too many questions but do you recommend starting with a particle wood when starting out or it all differs so much with the piece probably. Maybe I should build her a sand castle!! Jk thank you!
LittleGinas
#9 posted 05-05-2015 08:00 PM
Smitty_Cabinetshop
#10 posted 05-06-2015 03:25 AM
Avoid particleboard completely. It sags, the joinery is glue and dowels (at best) and often is covered with vinyl to make it look like wood.
Lots of solid wood pieces out there to rescue. Check yard sales and auctions if possible. Good luck!
View tomsteve's profile (online now)
tomsteve
753 posts in 1125 days
#11 posted 05-06-2015 08:31 AM
When looking for something to refinish, look at the end grain. It can tell you if you have solid lumber. Yu may also run into plywood, which can be used for large surfaces.but when refinishing care can need to be taken to not sand through the veneer on the plywood.
Good on ya for jumping into it. There’s a lot of good info on the www on refinishing.
And we like pictures of works in progress and finished projects.
View rhybeka's profile
rhybeka
3738 posts in 3027 days
#12 posted 05-06-2015 10:40 AM
what ^ said :) it’d be a nice paint piece if you were looking to try out milk paint or something (I’m sure that’s blasphemy here at some point :D) but most likely not 100% wood.
-- Beka/Becky - aspiring jill of all trades, still learning to not read the directions.
View dhazelton's profile
dhazelton
2689 posts in 2202 days
#13 posted 05-06-2015 01:57 PM
The grain of the wood is way to random to NOT be real wood veneer at the least. Back board is probably a cardboard with printed finish. I’ll venture that the doors and at least face frame are solid pine. You could touch that up easily just by dipping a rag in a light maple stain and applying it. If she has a use for it $50 is cheap.
