Fence Stops (yeap, also easy, fast and cheap)
Forum topic by niki posted 441 days ago 412 views 2 times favorited 10 replies Add to Favorites
View niki's profile
niki
386 posts in 608 days
441 days ago
Good day
I have seen many kinds of stops for the table saw sled fence and the drill press fence but…
I could not find any T-Track here, so I had to make something different…
The stops that I made have some “plus” on the T-Track ones – you can remove them out of the way very easy while the T-Track ones, have to be dragged all the way out unless, it’s on hinge but, I don’t like hinges because they always have some play.
Regards
niki
View Thos. Angle's profile
Thos. Angle
3409 posts in 490 days
441 days ago
You’re still at it and I’m still looking. Good one Niki
View brunob's profile
brunob
1391 posts in 697 days
441 days ago
you really do use sandpaper to its full advantage. So now I’ve got two of youer jigs to try to make tonight. Thanks for the ideas.
-- Bruce from Central New York
View niki's profile
niki
441 days ago
Thank you so much Thos and Bruce
Bruce
Sanding paper and super glue are my “Trade Mark” :-)
Sorry that I “gave” you some work….actually, I’m very happy….Thanks
Regards
niki
View TomFran's profile
TomFran
2369 posts in 522 days
441 days ago
Niki,
Yet another use for Super Glue! I never knew you could use it for that (welding a bolt in place).
I just just used some (super glue) this week to strengthen a hole in masonite – per your recommendation!
I even found some non slip sandpaper with the stickey back at the home center and put it on my miter gauge per Niki’s advice.
Keep them coming!
View lclashley's profile
lclashley
231 posts in 642 days
440 days ago
You’re the man!
View niki's profile
niki
440 days ago
Thank you
Sorry for the late reply…did you know that wedding in Poland takes two days and you have to stay overnight…now, I also know..
Tom
There is another use for the super glue…to lock nuts to bolts…you just put a drop between the nut and the bolt (kind of, into the nut) and it will not open by itself.
I was locking nuts that way on the “Engine mounting bolts” of the “radio control flying model”... those two stroke engines are vibrating like hell and many times the nuts were released…a drop of CA, and no more release.
To open the nut, it’s very easy, you just “crack” the locked nut with a wrench.
Regards
niki
View porrapai's profile
porrapai
10 posts in 411 days
373 days ago
Niki
Your ingenuity is remarkable. I have been going through some of your projects and learned a few tricks. Thank you for sharing your ideas, some are very simple and effective. Let me ask a personal question. Do you have dreams at night leading you to these results?
Thank you once again for sharing
PorraPai
South Africa
Carlos Castanheira
porrapai@gmail.com
-- carlos castanheira, South Africa
View niki's profile
niki
373 days ago
Thank you Porrapai
So you were “digging” through my posts….now I understand why my Photobucket account “monthly bandwidth” went up to 15 GB…Just joking…
As far as I know, I don’t have any dreams about jigs but sometimes, I’m just looking around my small garage and it “clicks”...I don’t know how or why…
Regards
niki
View mski's profile
mski
263 posts in 508 days
371 days ago
Good job, what I like about your jigs are the cost!
You should really writhe a book with all them in it!
-- MARK IN BOB, So. CAL
View brad's profile
brad
114 posts in 432 days
371 days ago
Very cool and useful, I may give it a shot myself.
-- Brad,--"The way to eat an eliphant is one bite at a time"
Bookmark And Share This Page
