Inexpensive kiln dried lbr?
Forum topic by JerryLH posted 05-03-2015 10:52 PM 1033 views 0 times favorited 9 replies Add to Favorites Watch
View JerryLH's profile
JerryLH
134 posts in 1311 days
05-03-2015 10:52 PM
Topic tags/keywords: cheap lumber secondary lumber
There may be no such thing as ‘inexpensive kiln dried lbr’—but I still need to ask the question. Since the project I’m thinking of would have all the components – but the top – completely covered by a hard surface veneer – the lbr need not be pretty – just stable. (I’m not sure at this point what the veneer will be—it won’t be a wooden veneer). Thanks for your help!
-- Develop your character -- for it becomes your destiny. Jerry - Mannford, Ok
9 replies so far
View bonesbr549's profile
bonesbr549
1549 posts in 3067 days
#1 posted 05-03-2015 11:19 PM
If veneer then solid wood not advised. It will expand and contract at a rate diff from the veneer and split and crack. For ansuvbstrait to veneer plywood is good or Mdf. What is the project details Really can’t give a blanket statement. Is it to be painted or a finish with a stain or dye?
View AlaskaGuy's profile
AlaskaGuy
4139 posts in 2309 days
#2 posted 05-04-2015 12:27 AM
I don’t understand. What exactly is “a hard surface veneer”?
JerryLH
#3 posted 05-04-2015 03:04 AM
I don’t blame you for not understanding – I wasn’t sure what to call it. I believe I mentioned that the veneer, ‘won’t be wood’. In my mind – a hard surface veneer – would cover things like formica, plastic sheeting or some sort of metal sheeting. I used copper roofing sheeting to cover our kitchen cabinet countertops and backsplash. In the pic you can see the countertops. I’m thinking on how I can combine
wood and metal more in furniture.
AlaskaGuy
#4 posted 05-04-2015 05:19 AM
An important piece of information is missing in your post. What’s the project??
View Moron's profile
Moron
5032 posts in 3893 days
#5 posted 05-04-2015 05:37 AM
generally speaking
kd timber
is not only expensive
but will remain a measure of time : )
JerryLH
#6 posted 05-04-2015 02:47 PM
I don’t mean to be intentionally vague but ’the’ project has not been determined. I mentioned in my initial question it could be ’all’ the components of a table but the table top itself. So, what say yee – I would appreciate any and all feedback.
bonesbr549
#7 posted 05-04-2015 03:03 PM
Ok, if you are going to cover it, what about the inside? Are you going to have a nice insiide face? The reason I ask is, if it’s just like an island type deal, then use construction grade pine. It’s cheap and will support the other material just fine. If it’s formica or something that will be glued down, the mdf works great for adheasion with contact cement.
If the inside is to be seen like in base cabinets, then I’d go prefinished ply. If you must and I mean must have HW, then poplar is stable and will be reasonable in cost still. Great paint grade, and can be finished with dye if you know what you are doing.
Again, if you are building a shell I’d not sink HW under it. But that’s me.
View TheFridge's profile
TheFridge
9477 posts in 1486 days
#8 posted 05-04-2015 03:14 PM
Formica/melamine should be glued to sheet goods and not solid panels.
JerryLH
#9 posted 05-04-2015 05:15 PM
Ok, if you are going to cover it, what about the inside? Are you going to have a nice insiide face? The reason I ask is, if it s just like an island type deal, then use construction grade pine. It s cheap and will support the other material just fine. If it s formica or something that will be glued down, the mdf works great for adheasion with contact cement. If the inside is to be seen like in base cabinets, then I d go prefinished ply. If you must and I mean must have HW, then poplar is stable and will be reasonable in cost still. Great paint grade, and can be finished with dye if you know what you are doing.
Again, if you are building a shell I d not sink HW under it. But that s me.
- bonesbr549
Thanks so much – that sounds just like what I am looking for. Hardwood is ‘not’ a requirement. Construction grade pine sounds like what I need – i.e. wrapping a leg or rail (or similar component) in copper sheeting.
Thanks to all.
