Is Appleply plywood suitable for outdoor projects?
Forum topic by DGjohn posted 1380 days ago 1805 views 0 times favorited 4 replies Add to Favorites Watch
View DGjohn's profile
DGjohn
1 post in 1401 days
1380 days ago
I have a small shop. This means that usually make something, I use 4s wood from HD or Lowes.
If I do this for making Adirondack chairs, the wood cost will be approximately $250.00. Ouch. Ouch Ouch.
I have found that Applyeply is about $60 per 48×96 sheet. Now this is in my budget.
Would using this material be suitable for this project?
Thank you for your help.
John
View Sam Yerardi's profile
Sam Yerardi
244 posts in 2063 days
#1 posted 1380 days ago
If the chairs are to be for inside the home or patio, it might be. I would not use it outside as I would be concerned in a couple of areas:
1. I would be concerned that the plywood will delaminate in exposure to weather, i.e., rain, etc.
2. I don’t believe the wood used in appleply is an inherently water-resistant material.
If it is for outsde and you want to use plywood, I would only consider marine-grade plywood. But at that expense you might as well use redwood, cedar, or treated lumber.
IMHO
-- Sam
View Dan Lyke's profile
Dan Lyke
1366 posts in 2293 days
#2 posted 1379 days ago
If you can get Appleply for $60 per sheet, I’ll buy it from you for $80 and still save $40-50 over what I’m paying… Are you sure that what you’re seeing is Appleply? Around here, that’s a voidless hardwood plywood with somewhere upwards of 13 plies in a 3/4” sheet with a veneer surface.
I use it for cabinets and drawers. I wouldn’t use it for outdoor stuff unless I were sure of my finish. It will delaminate.
For Adirondack chairs I’d go for redwood or cedar, and if it’s costing you $250/chair, you can pay for a benchtop planer right fast.
You might also consider seeing if your local high end deck place can sell you cedar in a bigger thickness and you can rip it down to a usable size for your chairs.
View PurpLev's profile
PurpLev
7741 posts in 1816 days
#3 posted 1379 days ago
def. wouldn’t use plywood for outdoor projects. unless you don’t plan on keeping them for long.
I’m on the same boat though – lumber that is fitting for outdoor use (redwoods, cedar) are somewhat expensive here in Boston area, and since I’ve yet to find a good reasonable supplier for those – I haven’t taken up on any outdoor projects as of yet.
I’ll be interested to see what others have to say about sources for this lumber as I too an interested. I like Dan’s idea about the local deck place.
View HokieMojo's profile
HokieMojo
2085 posts in 1896 days
#4 posted 1379 days ago
I have a frind that made the chairs from composite decking. It was expensive upfront, but they will last forever. they are also heavy, so you don’t need to bring them inside unless you are expecting hurricane force winds. (lol)
