| Forum topic by lobro4 | posted 106 days ago | 447 views | 1 time favorited | 10 replies | ![]() |
106 days ago |
106 days ago |
Actually laminated woods are as strong or stronger then the solid pieces…. For one you can be sure to eliminate any internal checks, knots or other flaws in each segment prior to glue up…whereas a solid piece is hard to see any that do not come through to the suface. As an example, I have 2 work benches….one with solid 4X4 supports and one that I built using 2 laminated 2×4’s. The mass produced shop made (was a bench I inherited) 4×4 has a bad crack going up the side of one support that I have had to glue and clamp. I will someday have to replace this one as the weakness is propelling the crack up the grain which is now into the metal spreader causing it to wobble when the bench clamp is in use for sanding. The bench I made from laminating has taken a heavy bit of service and the legs and spreaders are not having any problem keeping up and so far no wobbling and no cracking. That is just one example….I think there are just as many showing on the other side….but I think all in all you will get just as sturdy and item by laminating as you get from solids….and sometimes the smaller dimensional woods are easier to find and cheaper in most cases. Not to mention how easy it is to make the MT joints when the wood is in two pieces…. My .02 cents… -- Woodworking.....My small slice of heaven! |
106 days ago |
on a post the glue lines would just look horrible. but for something like a workbench the laminations would probably add more strength. but the masters before us for many centuries made big massive workbench legs out of solid wood and it worked out fine. |
106 days ago |
There’s always the quadrilinear method, made popular by the Stickleys. Makes a strong post, just have to get inventive with the top. -- Tim -- http://tmuli.com |
102 days ago |
Teenagewoodworker, I agree with. If the wood is properly selected and dried and all that, then solid legs should do the job just fine… and to be honest, unless the legs are really really, big, where you cannot find the lumber thickness you need or perhaps for design reasons, you really want to make a laminated look or for lack of machines to work thick lumber, then I would go with solid legs. Also the proper way to select solid wood legs is to make sure the grain is going toward the outside of the in a 45°angle from the middle. This to help make sure that the seam between the rails and the feet of the bed or table or bench, does not open up if there is any wood movement. A picture says a thousand words, Maybe this helps to explain what I am trying to say.
when proper wood grain choice is affected by wood movement:
when woodmovement affects such a corner with not so ideal grain choice:
so I hope this illustrates why you should watch which side faces outward as well that you can use solid legs with out a problem…. it just looks better -- Nicholas, Journeyman Cabinetmaker, Partenkirchen, Germany |
102 days ago |
Hey teen…........... we laminate posts all the time and turn them, paint them, stain them, etc. and we don’t have any problems with glue lines. If glued up and clamped properly, you won’t see much of if any glueline. And yes, they are stronger and more stable. -- Jerry--A man can never have enough tools or clamps |
102 days ago |
Good point, it can be that the legs are some what more resistant to movement, but, if you have nice straight grain it should not play a large role for legs on a bed/bench or table. I am of the opinion that the solid simply looks better. Sure you can have perfect glue lines (invisible) but still the grain has to be perfectly matched, which also uses sometimes more wood, than if one just used a good piece of solid material, up to a point, of course. I think this because if you have stips of wood in a leg, it can look like it was made with “scraps” or you ran out of wood or something… maybe even look like it was made by mass production. Just my opinion, thats all , Just for looks. -- Nicholas, Journeyman Cabinetmaker, Partenkirchen, Germany |
101 days ago |
Or you just need a really good finisher! -- Les, Wichita, Ks. (I'd rather be covered in saw dust!) |
101 days ago |
impossible question to answer |
101 days ago |
I use resin glues for laminating if I don’t want the glue line showing. Yellow glues are flexible and can show the glue lines with expansion and contraction. Titebond II also works well. -- Oldworld, Fair Oaks, Ca |
100 days ago |
Good discussion thanks for bringing it up! -- Only the Shadow knows.................... |
| Forum | Topics |
Woodworking Skill Share
2904 |
3927 |
256 |
943 |
223 |
Woodworking Trade & Swap
617 |
Coffee Lounge
2370 |
LumberJocks.com Site Feedback
522 |
