| Forum topic by Al Killian | posted 1410 days ago | 405 views | 0 times favorited | 1 reply | ![]() |
1410 days ago |
I have around 900 bft of Larch that is around 30% at present. We stacked it with 3/4” thick stickers every 18” and left 2” between each board in the rows. The bottom of the stack starts with two 8” post w/ stickers on them. We put plastic down to keep the moister from coming up thru the concrete. Then we built a 2×4 frame and put 8 mil plastic or it. There is a box fan in there on low and a small eletric heater which is holding at around 100 at present. We put in two 1/2” drain tubes for water. How long do you think it will take for this to gewt down to 12%? Most of it is is 8/4 some is 5/4,4/4. -- Owner of custom millwork shop |
