CLAMPING CAULS and FINISH
Forum topic by JUC posted 05-02-2015 07:14 PM 740 views 0 times favorited 9 replies Add to Favorites Watch
View JUC's profile
JUC
116 posts in 1888 days
05-02-2015 07:14 PM
I just finished building clamping cauls and am ready to glue up a table top. I do not want the cauls to be glued to my top. If I use Johnston’s past wax on the cauls will that effect any finish I apply to my table top.
Thanks for your help!!!
Jeffrey
-- If no one will ever see it, all the more reason to make it right
9 replies so far
View bbasiaga's profile
bbasiaga
1232 posts in 1993 days
#1 posted 05-02-2015 07:29 PM
Get clear packing tape and put it on the side that touche your product. The glue will not adhere to the packing tape.
Note this also works with any type of clamping block you may make/use.
-Brian
View JUC's profile
JUC
#2 posted 05-02-2015 07:34 PM
Thanks Brian, Does the packing tape need to be replaced after repeated use? if so, Does it come off easy or is it really stuck to the jig?
Jeffrey
Gerald Thompson
937 posts in 2232 days
#3 posted 05-02-2015 07:46 PM
I have had the original packing tape on mine for ages and no problems.
-- Jerry
View JUC's profile
JUC
#4 posted 05-02-2015 07:57 PM
Thanks Jerry, I have some scotch clear moving and storage tape. Is this what you are talking about?
Jeffrey
View Picklehead's profile
Picklehead
1041 posts in 1927 days
#5 posted 05-02-2015 08:15 PM
I usually cut notches in the cauls where they cross the glue lines to keep them from spreading the glue out onto the surface of the boards. Can also get in there with a narrow chisel or scrapermebobber to get the glue off before it fully dries.
-- You've got to be smarter than the tree.
bbasiaga
#6 posted 05-02-2015 08:46 PM
Don’t you want the cauls pressing right on the joint to keep it flat? I suppose if your boards are flat it wouldn’t matter.
And the tape lasts quite a long time. Just get a roll that is wide enough you don’t have a tape seam down your caul. Otherwise any clear packing tape works as far as I know. Saran wrap also works, but be careful as it tears easily. Tape is obviously superior because it is sticky and holds itself in place.
-Brain
View JUC's profile
JUC
#7 posted 05-02-2015 08:50 PM
Thanks for the help!!
tape it is.
Jeffrey
View waho6o9's profile
waho6o9
8190 posts in 2574 days
#8 posted 05-02-2015 09:37 PM
I finish the pieces first and then glue them up. :)
View wallyginter1's profile
wallyginter1
9 posts in 1122 days
#9 posted 05-02-2015 10:00 PM
Paste wax will repel all stain finish and cause a bad bond with glue.
-- Wally Ginter
