Square Taper Shanks - Adapt?
Forum topic by jross13 posted 08-08-2009 07:09 PM 2204 views 0 times favorited 1 reply Add to Favorites Watch
View jross13's profile
jross13
2 posts in 3299 days
08-08-2009 07:09 PM
Hello,
I am looking for an adaptor with a square taper shank chuck on one end
and a standard shaft on the other that would allow me to use my large
collection of square taper shank wood augers with a power drill.
OR, any suggestions that would allow me to chuck the bits into a standard chuck
on a drill press or hand drill?
Thank you,
J. Ross
1 reply so far
View MrRon's profile
MrRon
10 posts in 3329 days
#1 posted 08-08-2009 10:58 PM
You have two choices. You can either cut the tapered portion of each auger bit off or you can cut the chuck off a bit and brace and chuck the B/B chuck in the electric drill. I would go with the former since it looks like you don’t want to drill by hand anymore. I know of no adapter that is available. You might just check with Lee Valley/Veritas. If such an adapter is available, they would have it. Just looked at the LV/V site and they don’t have an adapter. Cutting off the chuck from a bit brace, won’t work either, so the first suggestion is my best solution.
