Removable table top
Forum topic by dan_fash posted 05-01-2015 10:06 PM 863 views 0 times favorited 4 replies Add to Favorites Watch
View dan_fash's profile
dan_fash
62 posts in 3390 days
05-01-2015 10:06 PM
Ok LJ’s. I would appreciate your help. I’m building a trestle table for a friend. The top is 6/4 oak slab, built up from 8” wide boards, without an apron. The top is 40×75”. He asked if it was possible to make the top removable, for moving (military family). I’m a bit unsure of how to accomplish this without risking the solidness of the table… I thought I could use lag screws through the central support beam (under the top) with slotted holes on the edges of the two horizontal legs, but I don’t know how this will age. Open to any ideas…
Thanks for your help!
-- "If I find in myself a desire which no experience in this world can satisfy, the most logical explantion is that I was made for another world." -C.S. Lewis
View madts's profile
madts
1855 posts in 2304 days
#1 posted 05-01-2015 10:19 PM
I would just use cleats screwed to the bottom of the top against the legs. That should age pretty well. Also easy to break down.
-- Thor and Odin are still the greatest of Gods.
View bondogaposis's profile (online now)
bondogaposis
4682 posts in 2315 days
#2 posted 05-01-2015 10:36 PM
Put threaded inserts into the top and attach it w/ bolts instead of screws.
-- Bondo Gaposis
View bigbeu's profile
bigbeu
1 post in 1085 days
#3 posted 05-02-2015 01:51 AM
Your idea is best – slotted holes. You won’t need lag screws – just ordinary wood screws of appropriate length. My trestle table has gone 30 years so far and still together.
dan_fash
#4 posted 05-02-2015 04:40 PM
I was wondering about the threaded inserts too. Will they have a strong enough hold? Normally a plank top like this I’d glue the center support, leaving the outside legs unglued for expansion. (Thus the slotted holes too) and this table is a beast. Almost a hundred bft of red oak. The idea is that this table should outlive them.
