Need help aligning table saw
Forum topic by Alster posted 114 days ago 355 views 0 times favorited 10 replies Add to Favorites Watch
Rockler
View Alster's profile
Alster
2 posts in 114 days
114 days ago
Topic tags/keywords: table saw alignment
I recently purchased a very lightly used Jet contractor’s saw, and plugged it in today for the first time. When I checked, the blade was skewed to the miter slot by about 1/16 of an inch front to back. So I spent some of the afternoon loosening the trunnion bolts, installing a PALS kit, and trying to get things lined up.
At the end of the afternoon, I still couldn’t get the blade parallel to the miter slot. I’ve got the front of the trunnion all the way to the right, and the rear of the trunnion all the way to the left, and it still needs just a shade more—about a 32nd of an inch. And I think I’m out of room to adjust it any further.
So here’s my question. Or questions. 1) Is it possible that Jet produced a saw with a blade that can’t be set parallel to the miter slot? 2) Or am I doing something wrong? And 3) If your answer to either 1) or 2) was yes, your suggestions on how to fix this problem are VERY much appreciated.
Alan
View ajosephg's profile
ajosephg
443 posts in 461 days
114 days ago
Alan -
I had a similar issue with another brand contractor’s saw, and the ultimate solution was complete dissassembly of the saw and drifting the trunnion slot holes with a rat tail file. (I couldn’t get my saw any closer than about 0.015 before, after the modification I have the alignment at 0.002.)
I assume you removed the trunnion bolt washers before you installed the PALs kit. If you didn’t that could be the problem as the original washers may be hanging up in the slots.
I wrote a paper on everything I went through with photos. If you want to see it, send me a PM with your email address.
-- Joe
View Jimmy's profile
Jimmy
26 posts in 240 days
114 days ago
i went through a similar issue aligining my delta contractor. one thing that helps is pick up a 10 inch abrasive wheel and use that as the alignment blade. is is more uniform all around and worked great for me. good luck
-- 20 year old new woodworker. advice and tools much appreciated.
View knotscott's profile
knotscott
539 posts in 275 days
113 days ago
Alan – Assuming this saw has connecting rods, it’s possible that the rods have twisted within the brackets and are causing this problem. To check that, set the blade at 90 degrees and lay something perfectly flat (like a small pane of glass) across the rods….if the plate rocks, the rods need to be loosened and adjusted before you can align the trunion brackets.
Elongating the holes is another possibility of the alignment is really whacked. It’s possible it’s been that way since the saw was new. If you go to that much trouble, make sure the mating surfaces between the table and brackets are smooth and flat, and you might as well upgrade the bolts and washers to a better grade of steel while you’re at it…at least that way you’ll be eliminating possible alignment causes down the road.
ajosephg
113 days ago
Knotscott is right about replacing the bolts.
I replaced mine with studs and used threadlocker to hold them in place. That removes any wear and tear and the table top threads – which if stripped will cause great grief.
-- Joe
View Maknsawdust's profile
Maknsawdust
6 posts in 109 days
109 days ago
Anybody want to buy a powermatic 64 with stripped threads in the table. No. 5 bolts ripped the threads right out…but the zine bolts would not tighten.
I think it’s time to buy a R4511 so I can saw wood and not rebuild saws. Good Luck.
-- Round tuit's don't do it, just get a round toit, avaiable where buckets of steam are sold.
View Chris Wright's profile
Chris Wright
360 posts in 381 days
109 days ago
You can see if the table top can be twisted any. I’m not sure how it’s attached, but if there’s some room for adjustment that way, you might look into it. Just a thought.
-- "At its best, life is completely unpredictable." - Christopher Walken
View TomHintz's profile
TomHintz
83 posts in 298 days
109 days ago
I had a Jet contractor-sthyle saw and the trunnions are mounted directly to the table (as are most saws in this class) so that would eliminate moving the table itself.
I have heard of people elongating the holes in the trunnion slightly to get the blade aligned correctly. If you are out by a full 1/16” over the length of the blade that would mean that a bit over 1/32” on each trunnion should give you enough room with a little fudge factor as well.
Also, make sure that you are measuring it correctly and accurately. I have seen a few saws that the owners had gotten some comfusing instructions on measuring this alignment. We later found on each of them that it was much closer than they thought. Sometimes taking a day off and coming back at it with fresh eyes helps a bunch.
-- Tom Hintz, www.newwoodworker.com
ajosephg
108 days ago
Makinsawdust:
FYI – the stripped out holes in your saw table top can be fixed with Helicoils.
-- Joe
View JJohnston's profile
JJohnston
121 posts in 191 days
108 days ago
If you decide to remove the trunnion assembly from the table, it’ll be easier if you have someone help you turn the entire saw upside down so you’re not fighting gravity. I once overloosened the bolts on my contractor’s saw, just enough to allow the the trunnion assembly to fall out of the brackets. I ended up having to turn the saw over, by myself, to get it back together. If you do turn it over, pick it up – don’t let the weight of the saw rest on the legs as it’s going over, or as you right it.
-- Measure twice, then try to figure out which one was right.
View drbob's profile
drbob
25 posts in 316 days
95 days ago
The following post on my website can provide with complet table saw tune up instructions including alignment http://www.woodworkingtipsandtools.com/2009/02/15/table-saw-tune-up/
-- drbob at http://www.Woodworkingtipsandtools.com
