Triton 2 1/4 HP Router
Forum topic by DonJ posted 08-07-2009 11:31 PM 1362 views 0 times favorited 7 replies Add to Favorites Watch
View DonJ's profile
DonJ
250 posts in 3521 days
08-07-2009 11:31 PM
I haven’t used this router in a while and was going to put in a 1/2” spiral bit in. It wouldn’t fit in the collit, so I took the collet nut off and thought I would try to pull the collet out to relieve any stress. I’ve been unsuccessful in removing the 1/2” collet. I know this is a “double clutch” system (don’t know what to properly call it) where you un-loosen the collet nut, it sticks again, and you continue to un-loosen until you can remove the router bit. I don’t know how, but it appears the collet is stuck in between the two loosenings??? Any suggestions? Thanks
-- Don, San Antonio, TX
7 replies so far
View Kindlingmaker's profile
Kindlingmaker
2656 posts in 3520 days
#1 posted 08-07-2009 11:56 PM
You most likely don’t want to hear this one… WD-40 and brute force. (After working the nut back and forth with the WD-40)
View DonJ's profile
DonJ
#2 posted 08-08-2009 12:14 AM
Well, I did get the collet out, but still can’t get a router bit in the collet. It must have gotten sprung (sp?). Any ideas about resetting the collet, or am I going to have to order a new one? Thanks,
View reggiek's profile
reggiek
2240 posts in 3264 days
#3 posted 08-08-2009 12:48 AM
I would recommend a new collett….nothing is worse than having a bit get loose. There are too many horror stories to tell on that accord (broken bit, destroyed project are the lower side of the spectrum – Injuries are on the other end)....and a collett is not that expensive.
Just call me over cautious…
View jerryz's profile
jerryz
164 posts in 3272 days
#4 posted 08-08-2009 01:31 AM
Well obviously your colett suffered some permanent deformation as a result of being forced to stay in a constricted form well beyond it’s normal shape.
The colett is made of springy steel and even if you could attempt to restore it to it’s normal shape I don’t recommend it. Get a new colett. You don’t want to break when it’s spinning at 20k rpm
Be safe….
View Eddy's profile
Eddy
25 posts in 3353 days
#5 posted 01-13-2010 03:55 AM
this just helped me. I have to get the collet out now.
-- Edward
View PurpLev's profile
PurpLev
8535 posts in 3642 days
#6 posted 01-13-2010 04:13 AM
I’ll join the ‘get new collet’ choir… it’s fairly simple, and the safest route.
View sh2005's profile
sh2005
97 posts in 3230 days
#7 posted 01-13-2010 03:33 PM
I purchased what I now think is a returned/reconditioned Hitachi KM12VC router from online (even though the website didn’t mention anything, but it was cheaper) and the 1/2” collet wouldn’t accept bits without a lot of fuss. Bits wouldn’t go in smoothly. After I pushed it in, it would work but after removing the bit, I would see scratches all over the bit’s shank. The tolerances on the collets are so tight that I figured I wouldn’t be to restore it to its original form. I got a new one.
