Bosch Jig Saw trouble. Cant control cut
Forum topic by craigpro posted 05-01-2015 02:40 PM 736 views 0 times favorited 4 replies Add to Favorites Watch
View craigpro's profile
craigpro
1 post in 1026 days
05-01-2015 02:40 PM
Topic tags/keywords: bosch jigsaw
Bosch Jig Saw Bosch 1590 EVSL .. cant control cut.
This saw worked great for a while, but has developed an issue with the control of the blade.
When cutting the slightest curve, the blade jumps out of the guide roller and keeps going straight.
Have tried this with several different blades, precision control guide on and off, etc.
It looks like the blade can move forward too easily slipping away from the guide roller. If the precision control guide is engaged the guide blocks only touch 50% of the blade.
See picture showing the blade position after another frustrating attempt to cut a usually easy, wide circle.
Any advice would be great.
Thx
View syenefarmer's profile
syenefarmer
483 posts in 2984 days
#1 posted 05-01-2015 09:01 PM
Remove the blade and spray some air into the blade receiver. It’s possible that some sawdust has gotten up there and is preventing the blade from seating properly. Or, it could be something else….............but that’s my WAG.
View BurlyBob's profile
BurlyBob
5242 posts in 2169 days
#2 posted 05-02-2015 03:23 AM
I’ve had trouble with my Bosch not cutting 90 degrees. Fiddled around with it and found that the base slides back and forth to lock in position. You might have to do some fiddling with yours to find the secret. I’ll take a look at mine tomorrow and see what I can figure out. If I come up with something I’ll get back at you.
View waho6o9's profile
waho6o9
8099 posts in 2480 days
#3 posted 05-02-2015 03:47 AM
View Jim Finn's profile
Jim Finn
2614 posts in 2825 days
#4 posted 05-02-2015 12:26 PM
On my Bosch the lever in your photo adjusts the blade guide forward or back. You might try adjusting that. In your photo you have it in the retracted position.
