Mocking up with 2x4's/2x6's?
Forum topic by CharlesA posted 05-01-2015 01:03 AM 788 views 0 times favorited 5 replies Add to Favorites Watch
View CharlesA's profile
CharlesA
3361 posts in 2037 days
05-01-2015 01:03 AM
Topic tags/keywords: question
I’m designing a couple of projects that are made from 8/4 or 4/4 stock, but have some engineering challenges. I’ve made models in sketchup, butI’d like to see how they are in real life. I’m thinking of making a full-size model out of 2×4’s/6’s. I want to check things like balance and stability, so I want to use as close to the real thing as possible, but also something I can do quickly.
Anybody ever made a full-scale model/mockup out of construction lumber?
5 replies so far
View JAAune's profile
JAAune
1854 posts in 2557 days
#1 posted 05-01-2015 01:24 AM
Nope, but I’ve seen plenty of people do it. That plus particle board, foam and all sorts of other rigid and semi-rigid materials. It’s unlikely you’ve ever been to Michael Fortune apprenticeship class at Marc Adams School but if you have, you’d be amused at the total chaos of wood scraps and foam strewn about the students benches.
The goal is to just stick parts together with screws, hot melt glue, tape, wire or whatever it takes to hold the parts in place while they’re analyzed.
View bonesbr549's profile
bonesbr549
1579 posts in 3307 days
#2 posted 05-01-2015 01:35 PM
I have. I was making my first 8 sided pencil post bed and wanted to test the jigs I had made to make sure they worked. I used glued together pine 2×4’s milled down to spec and it worked great! Not cheap but one hell of a lot cheaper than trying it live fire with very expensive cherry 12/4”
View JADobson's profile
JADobson
1335 posts in 2351 days
#3 posted 05-01-2015 02:46 PM
I’ve made some actual furniture out of construction 2×4s and it works just fine. I can’t imagine how it wouldn’t work for a mock up.
Click for details
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany — Instagram @grailwoodworks
View pintodeluxe's profile
pintodeluxe
5819 posts in 3053 days
#4 posted 05-01-2015 03:43 PM
I tend to buy rough lumber in large quantities. When I want to mock up a chair, I just use the second quality hardwoods. There is always some stock with cracks and knots that is destined for the wood recycler anyways.
I think chairs are the best place to use prototypes, because it may look right in a scaled drawing… but one sit will tell you it’s not.
Case goods are easier to mock up with cardboard.
CharlesA
#5 posted 05-02-2015 11:13 AM
I wouldn’t do this in most cases, but I did try it yesterday and it is a ball. It’s amazing how fast I could build something with soft wood and no concern for detail. I put together an accurate full-size model in about 4 hours-it will take me a couple of weeks to build the real thing.
