Varnish and Lacquer
Forum topic by wallyginter1 posted 04-30-2015 06:21 PM 739 views 0 times favorited 6 replies Add to Favorites Watch
View wallyginter1's profile
wallyginter1
9 posts in 997 days
04-30-2015 06:21 PM
Iv been using a variety of oils on my recent projects and it really brings out the grain but what imm looking for is something preferably spray on that provides a shell aroud he work piece. I have also tried some spray on laquers and varnishes but they just seem to streak
-- Wally Ginter
View Wildwood's profile
Wildwood
2204 posts in 2008 days
#1 posted 04-30-2015 06:48 PM
Are you using spray can or spray gun? Are you spraying over an already applied oil finish? Hard to figure out whether problem is product you are using and or technique.
-- Bill
wallyginter1
9 posts in 997 days
#2 posted 04-30-2015 07:06 PM
I have been using spray can premium decor lacquer and it seems to streak with the grain and it was on barewood
-- Wally Ginter
View bbasiaga's profile
bbasiaga
1055 posts in 1868 days
#3 posted 04-30-2015 07:14 PM
Perhaps you are too close to the work with the can when spraying.
-Brian
View gridlockd's profile
gridlockd
141 posts in 2258 days
#4 posted 04-30-2015 08:28 PM
try putting a coat of sanding sealer on prior to the lacquer. it’ll seal the woodgrain so you can get an even coat of lacquer. I noticed with some of my turnings that i was getting that “streaking” effect sometimes. sanding sealer did the trick for me. JM2C
-- Gridlockd
Wildwood
#5 posted 04-30-2015 08:38 PM
I would lightly sand with 220 or 320 grit until streaks are gone and try spraying again! JMHO would not use sanding sealer now because you do not want to sand all the way back to bare wood.
-- Bill
View Dark_Lightning's profile
Dark_Lightning
3025 posts in 2982 days
#6 posted 05-03-2015 01:57 AM
-Brian
- bbasiaga
Yes, sounds more like runs, which are easy with lacquer. A pic would help immensely.
-- Random Orbital Nailer
