Milling Stock
Forum topic by VerteramoFurniture7 posted 115 days ago 240 views 0 times favorited 7 replies Add to Favorites Watch
View VerteramoFurniture7's profile
VerteramoFurniture7
36 posts in 160 days
115 days ago
Topic tags/keywords: milling tablesaw jointer planer
Hey Guys,
I was just milling up stock for some kitchen cabinets. The following are the steps I have done so far.
1. Cut board down in size with miter saw
2. Ripped boards down to 5-3/4” width to fit onto jointer.
3. Jointed 1 side
4. Planed down other side.
5. Joint 1 edge
6. Rip other edge on table saw 1/16 big.
To do
7. Plane all parts to final width.
Questions
1. Do you guys rough mill and finish mill your stock? i.e. joint 1 side and plane 1 side a bit thick then joint 1 side again and plane the other side again down to final thickness, letting the wood site an amount of time between rough and finish mill? (to let the stress work its way out of the wood)
2. When I was ripping the second edge on the table saw I was using a featherboard. Every cut I made was coming out bowed. Do you guys use a feather board at this step? When I didn’t use a feather board it seemed to be coming out right. Do you think it is the feather board that is causing the problem?
Thanks
Marcus
Craftsman on the lake
819 posts in 337 days
115 days ago
A good question. I’m going to follow this link as I’ve found a supplier for rough lumber.
-- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://web.me.com/deceiver6/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html
teenagewoodworker
2482 posts in 667 days
115 days ago
always rough mill and then finish mill. the inside of wood is always going to be more moist than the outside and have stresses in it that will need to be released. and a featherboard dosent keep the board straight it just holds it against the fence. so the featherboards not to blame for any movement your getting
View GarageWoodworks's profile
GarageWoodworks
210 posts in 522 days
115 days ago
To question 1, No.
I mill to thickness in one shot. The key is to remove the same amount of wood from both faces otherwise it can bow.
2. This might due to your technique when using the featherboard.
Are you using a splitter? If the splitter is misaligned it can throw off your rips.
One more thing. Are you confident that your rip fence is aligned properly?
-- Brian http://www.garagewoodworks.com
25811 posts in 1299 days
115 days ago
I always mill oversize, (Long, wide and thickness) and then finish to final size after a period of aging in the oversize mode.
All of my wood is rough sawn from a sawmill. All of my wood is air dried, unless you call storing wood in the attic of a barn that had a temp of 137 deg during the summer, something else.
View socalwood's profile
socalwood
968 posts in 503 days
115 days ago
listen to Karson !
GarageWoodworks
115 days ago
Marcus,
Don’t over complicate milling lumber. Face joint one side. Plane opposite face. Crank down the planer and plane opposite face. Crank down again by the same amount. Flip the board over and plane opposite face. Repeat cranking down the planer (by the same amount) and flipping faces until you reach your required thickness. I never have any problems when done this way. Good luck.
View CessnaPilotBarry's profile (online now)
CessnaPilotBarry
1290 posts in 602 days
115 days ago
I’m with Brian.
If you truly need to work the wood oversize and wait, you might not have the best stock, or you may need to study up on selection. Properly dried stock really won’t move that much, and the hand fitting process of assembling hand-made, one-off furniture will correct minor differences in size.
Remember… If you mill all properly selected wood that will be edge joined together, it will move in thickness together. If your edge joined top shrinks 1/8” in width, who cares? It will all shrink or expand at the same rate. Wood that doesn’t need to be edge joined often doesn’t require microscopic precision in thickness, and typical widths of rails and stiles, runners, etc… don’t require microscopic tolerances in width.
Furniture should be built with movement in mind. Waiting for the “perfect” moment to work the wood is futile.
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
