Pergala arch question
Forum topic by FancyShoes posted 04-29-2015 11:01 AM 949 views 0 times favorited 9 replies Add to Favorites Watch
View FancyShoes's profile
FancyShoes
539 posts in 1234 days
04-29-2015 11:01 AM
I have someone wanting me to build this pergala for them. I am wondering the best way to get this arc across the beam. I am thinking i can either use a router, with a jig/pattern, or if i should use a different route. I do see using 2 , 6’ length board to make it easier.
9 replies so far
View Woodendeavor's profile
Woodendeavor
276 posts in 2476 days
#1 posted 04-29-2015 12:41 PM
I think you have the right idea. Rough cut the curve with a band saw then true up to a pattern with a pattern bit in a router. You can cut the end profile at the same time
View Firewood's profile
Firewood
188 posts in 1504 days
#2 posted 04-29-2015 01:16 PM
Your post made me think of a plan I saw in Wood Magazine last year. Here is a link to the plan. It may give you a couple ideas.
Mike
-- Mike - Waukesha, WI
View HerbC's profile
HerbC
1706 posts in 2729 days
#3 posted 04-29-2015 06:10 PM
I would not recommend using two short beams to form each long beam. That will greatly weaken the structure.
Good Luck!
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View jerryminer's profile
jerryminer
846 posts in 1311 days
#4 posted 04-30-2015 06:40 AM
I’m with Herb here, although it looks like the original has some sort of connector at mid-span (maybe there’s a steel bracket covered by wood trim??). A full-length beam would be much stronger and long-lived, IMHO
View JohnChung's profile
JohnChung
398 posts in 1944 days
#5 posted 04-30-2015 10:08 AM
You can use a jig saw for rough cut. Then use the router with the template on the curve beam
View Nicoli's profile
Nicoli
31 posts in 993 days
#6 posted 04-30-2015 11:15 AM
I think jig saw is great way to cut it.
FancyShoes
#7 posted 04-30-2015 12:17 PM
So how wide of a board do i need? And whAt would the angle be?
jerryminer
#8 posted 05-01-2015 04:33 AM
- FancyShoes
That will depend on the dimensions of your pergola and how much arc you want. Got a design roughed out?
If you’re not a Sketchup user, you might consider checking it out (it’s a free download). I think it is a great design tool—-it will figure angles and arcs for you, and allow you to easily change and adjust at the design stage without wasting any wood!
FancyShoes
#9 posted 05-01-2015 01:10 PM
Ok thanks. I tried that program once, and it seemed ok. Will probably take some time to learn, but would be ueefull
