Question on this desk design
« back to Joinery forum
Forum topic by TraylorPark posted 04-29-2015 02:25 AM 881 views 0 times favorited 6 replies Add to Favorites Watch
View TraylorPark's profile
TraylorPark
213 posts in 1838 days
04-29-2015 02:25 AM
Topic tags/keywords: question furniture build
So I designed the desk below, but I am struggling with how I would go about attaching the drawer box to frame appropriately? I would like to avoid adding 2 additional legs on that side, but I also want it to be secure. Any thoughts?
-- --Zach
View cabmaker's profile
cabmaker
1744 posts in 3048 days
#1 posted 04-29-2015 02:31 AM
Yes………buuut then it would not be your design . looks like you have more than enough support at your disposal.
View BurlyBob's profile
BurlyBob
6032 posts in 2505 days
#2 posted 04-29-2015 02:35 AM
Taylor, That’s a lovely and elegant design to say the least. I’ll have admit you’ve asked an interesting question.
I wish I had the answer.
View pintodeluxe's profile
pintodeluxe
5819 posts in 3053 days
#3 posted 04-29-2015 02:57 AM
Here is how I did the framework for an L shaped desk…
http://lumberjocks.com/projects/114649
I used a combination of mortise and tenon, and pocket hole joinery. I really like your design, that will be one beautiful desk.
You might consider letting the panel from the bank of drawers extend down to the floor. You could cut away the front of the panel with a nice curved shape, which would maintain good foot room.
TraylorPark
#4 posted 04-29-2015 11:56 AM
So cabmaker is forcing me to use my noodle and here is what I came up with. What if I used a sliding dovetail into the table top? That should allow for seasonal movement of the top, correct? And if I use 1” thick material for the top there should be enough thickness above the joint for the top to be safe? More thoughts?
-- --Zach
View Kazooman's profile
Kazooman
1268 posts in 2192 days
#5 posted 04-29-2015 01:03 PM
In part it depends on what you intend to put in the drawers. If the bottom one is to be a file cabinet it could get pretty heavy. From your drawing I can’t really tell how the frame along the front works. Does the piece connecting the desk to the drawers just butt up against the end of the drawer unit or does it continue on to the right hand leg. If if is the latter, it should be plenty strong enough to support the drawer unit.
One other issue for consideration. It looks like you are going to have to move your chair out of the way every time you want to open a drawer. If you are limited by a specific location you would need to just live with that. Otherwise, changing some of the dimensions might make the piece more versatile.
View Nubsnstubs's profile
Nubsnstubs
1435 posts in 1970 days
#6 posted 04-29-2015 02:17 PM
Use the same method used in connecting counter top corners. Dog bones and draw bolts. Is that a 3” lap drawer in the offset portion? If not, turn that piece into a top rail and continue it to the right hand stile. You’ll get a lot stability that way. ............... Jerry (in Tucson)
