A frame finishing trick.
Forum topic by MarkTheFiddler posted 04-28-2015 04:21 AM 881 views 0 times favorited 7 replies Add to Favorites Watch
View MarkTheFiddler's profile
2068 posts in 2123 days
04-28-2015 04:21 AM
Topic tags/keywords: tip clamp
I know there are a whole bunch of ways to skin a cat. So here’s one more. If someone already does this, I’m not surprised.
It’s really hard to finish all sides of a picture frame unless you can get to all sides without touching an area you already added the finish to.
Try this.
Grab those tiny clamps that came with your Irwin set last black Friday. Yep – those clamps that never get used.
Go ahead and grab a hunk of plywood as well. Make sure that plywood has at least one measurement smaller than the interior rabbits of the frame.
Clamp them to the plywood.
Mount the picture frame on the ends of the clamps.
If you don’t have those itsy bitsy clamps, smile. The six inch clamps work better and the 12 inch clamps even better than those.
Notice the scrap of wood I used as my base. I just added two clamps to one side roughly even with each other. I added the other two about 2 inches past where the frame will rest. I mounted the rabbit on the fist side then pulled the whole thing toward the other clamps until I could seat it on the second set of clamps. Now the frame is mounted and pretty secure because those clamp set are pulling away from each other. Call it spring loaded tension.
Apply finish and set the whole thing off to the side to dry. Yee-haw!!
-- Thanks for all the lessons!
7 replies so far
View Joe Lyddon's profile
Joe Lyddon
10012 posts in 3987 days
#1 posted 04-28-2015 04:28 AM
New approach to holding the workpiece so it can be Finished…
COOL… :)
-- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: ... My Small Gallery:"
View MrUnix's profile
6491 posts in 2133 days
#2 posted 04-28-2015 04:31 AM
Great idea… I’ll have to give it a try next time I do a frame!
View hotbyte's profile
991 posts in 2910 days
#3 posted 04-28-2015 10:56 AM
Great tip!
View conifur's profile
955 posts in 1086 days
#4 posted 04-28-2015 01:14 PM
thanks for the tip, very timely for me, need to make up a pic frame to hold a mirror for my nephews new bathroom vanity.
View Jim Jakosh's profile
Jim Jakosh
20179 posts in 3040 days
#5 posted 04-28-2015 01:29 PM
Good tip, Mark!!
#6 posted 04-28-2015 03:49 PM
- conifur
Howdy conifur,
I hope it works well for you. Let me know how you like it.
Thanks very much for the feedback.
View Bill White's profile
Bill White
4879 posts in 3895 days
#7 posted 04-28-2015 04:25 PM
Well thought Mark.
