16" jointer use
Forum topic by AZWoody posted 04-28-2015 12:13 AM 1081 views 0 times favorited 12 replies Add to Favorites Watch
View AZWoody's profile
AZWoody
1265 posts in 1131 days
04-28-2015 12:13 AM
I currently have an 8” steel city granite jointer and would like to get something larger.
With my sawmill, I do a lot of face jointing as well as edge jointing and 8” is turning out to be too narrow for me.
I’ve thought of upgrading to a 12” but I was wondering how much of a difference 4 more inches would make. Going to a 16” is a major, major jump in price though. What I wonder though, at that size, is it almost too large of a practical size to be using with one person? Does trying to use a 16” become too unwieldy?
I’d be interested to know what anyone with experience using them have to say about them.
12 replies so far
View pintodeluxe's profile
pintodeluxe
5568 posts in 2720 days
#1 posted 04-28-2015 06:12 AM
I think 12” would be a good size for most planks. Actually boards wider than 12” are prone to checking and warping anyways. Even if you had a 16” jointer you would likely rip them down to more manageable size before jointing.
I use an 8” jointer, because most of the quartersawn oak boards I encounter are 5-8” wide.
View Texcaster's profile
Texcaster
1271 posts in 1581 days
#2 posted 04-28-2015 08:03 AM
The real value of a large machine is being able to dress glued up panels. I have a 400mm or 16in over and under, almost perfect for most bits of furniture. Example, a door or framed cab. side with a 16in panel and 2 1/2 in stiles is a wide panel. Most of my cases have been sub 16in. For larger work, two dressed halves are joined.
-- Mama calls me Texcaster but my real name is Mr. Earl.
View bigblockyeti's profile
bigblockyeti
4992 posts in 1627 days
#3 posted 04-28-2015 12:32 PM
We had a 16” jointer where I used to work and it was great for cleaning up custom glue laminated beams. We did have a chainfall overhead to handle the beams which in some cases were over a ton. I was at least a two person job, especially with the larger ones we made.
View AlaskaGuy's profile
AlaskaGuy
3912 posts in 2216 days
#4 posted 04-28-2015 12:36 PM
- Texcaster
+1
I too have a 16” J/P. Even at that I sometimes wished I had got the 24’’ but never wished I had smaller.
View Kaleb the Swede's profile
Kaleb the Swede
1808 posts in 1876 days
#5 posted 04-28-2015 01:25 PM
https://www.youtube.com/watch?v=y0335X42KRs
This guy is has an even bigger jointer planer. 25 inches to be exact. If you watch the video it doesn’t seem too unwieldy for him.
I wish…..with my little bench top 6 inch jointer..sigh. Best of luck to you
-- Just trying to build something beautiful
View jdh122's profile
jdh122
983 posts in 2724 days
#6 posted 04-28-2015 01:41 PM
I thought there were double-sided planers that can both joint and plane at the same time. The biggest ones are for industrial-size sawmills, but are there no smaller ones that might be more reasonable (especially given how much 16’ jointers cost). Or maybe I’m totally off-base?
-- Jeremy, in the Acadian forests
View SirIrb's profile
SirIrb
1239 posts in 1137 days
#7 posted 04-28-2015 01:50 PM
This!
I want pictures and stories.
This is a must.
- bigblockyeti
AZWoody
#8 posted 04-28-2015 03:56 PM
That 25” planer would be awesome to have.
Anybody use the 16” combos? The one thing that always makes me think twice is the short length of the tables
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1083 days
#9 posted 04-28-2015 04:13 PM
The real question is how wide are the logs you run through your sawmill. If you are milling rough boards that are always under 12” then a 12” jointer will be sufficient. If you regularly saw boards between 12 and 16” then you have your answer.
For an occasional board you could use a planer sled to join the first face if your planer is wide enough.
AZWoody
#10 posted 04-28-2015 04:33 PM
- WoodNSawdust
Boards vary from 4 inches on up to 24 inch slabs. I do have a 20” planer that I can do a sled but at that size, it gets pretty heavy and will need help which I can get from time to time.
I might have to go with a 12” unless I can find a 16” that I can find a price that’s not double the 12, which is what I’m finding for the most part.
AlaskaGuy
#11 posted 04-29-2015 11:52 AM
- pintodeluxe
It’s seems like not many realize the advantages of gluing 2 or 3 of those 5-8’’ wide boards together before you face joint. When I need a glued up panel for cabinet doors I’ll do just that then flatten the whole mess as one board and then thur the planer.
I see lots of post where people have trouble getting their glue ups perfect aligned. This eliminates this problem.
Wide jointer can be very useful even you only have stock the 5-8’’ wide.
View gfadvm's profile
gfadvm
14940 posts in 2597 days
#12 posted 04-30-2015 12:29 AM
The huge advantage to a big (24-25” jointer) is you can skew/angle the board and have less tear out as well as being able to joint wide stock. I troll CL daily looking for a BIG jointer!
